Home > Technical (L322) > Rear seat base removal
VaguelyVogue
United Kingdom 2006 Range Rover Vogue Td6 Buckingham Blue
The children have managed to drop some bits down the gap around where the rear seatbelt sockets go - is there an easy way to lift the rear seat bases to get them out or do I have to start unbolting things (a quick inspection yesterday didn't reveal any obvious levers or buttons) ?
Post #16887 19th Apr 2010 3:34pm
M44K TS
I think when you fold the seats forward, there's some carpeted trim which is held on by black plastic push in clips, I dare say if you remove the clips you might be able to get to the back of the seat base.
Could be worth a try? 2006 Mercedes CLS
1991 Retro-style Mini
But really finding it hard to fight the urge for a S/C...
Post #16901 19th Apr 2010 4:33pm
VaguelyVogue
Thanks - I'll give that a go tonight !
Post #16966 20th Apr 2010 8:26am
I would have thought just folding the seats all the way forward will give you access won't it? Discovery 4 HSE
Post #16968 20th Apr 2010 8:28am
Macdaddy
2003 Range Rover Autobiography 4.4 V8 Java Black
As above...
Fold the seat back forward then folding the seat base forward will allow access to the crap/crumbs underneath.
Until this weekend i didnt realise the base folded up this way....... it revealed all the crap from previous owners ! Big Cry TDV8 HST Sport **Current**
4.4 V8 Autobiography and 22" wheels **Gone**
Post #16972 20th Apr 2010 9:39am
VaguelyVogue
Oh B*gger - that's far too obvious - sounds like a severe vacuum might be required tonight too then - thanks !
Post #16980 20th Apr 2010 10:34am
VaguelyVogue
It nearly worked !
As per the very helpful suggestions above, fold the seat backs down and then lift the rear of the base to reveal .... lots of rubbish on the carpet below.
However, the seat belt "sockets" in the seat bases are in their own holder which may require a torch and tweezers to extract small items when the seats are returned to the sitting position !
Post #17066 21st Apr 2010 8:42am
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
One you have the bases moving - simply smack them on the back and small items will fall out Wink there is plenty of scope for movement - especially if you move the front seats as far forward as you can.
Post #17067 21st Apr 2010 8:52am
Or just use the thin hoover nozzle and suck out whatever is in there. if it's a valuable, empty the hoover first so when you retrieve it from the bag it's not caked in all the rubbish. Discovery 4 HSE
Post #17068 21st Apr 2010 8:55am
