Home > Maintenance & Mods (L322) > Replacing Air suspension this weekend
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
OK - I bit the bullet and have 2 new front air suspension legs coming for replacement this weekend (as my FR has blown)
I also got new lower bolts as I hear they can be a pain.
Is there anything special I need to know before I start or a step guide to help me..?
I gather I need to depressurise the bags first (completely..?)
Liberally spray bolts with WD
Jack car up
Remove wheels
Undo lower bolts
then middle
then Engine bay
then air hose
then remove
Fit in reverse order
Then calibrate (with newly aquired IID tool Smile )
Anything I missed.?
Thanks folks (and wish me luck) Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #169279 1st Feb 2013 9:53am
rathbranV8
Ireland 2002 Range Rover SE 4.4 V8 Oslo Blue
check out RSW Solutions in the wiki,they have some videos on how to do it
http://rswsolutions.com/index.php?option=c...;Itemid=78 Thumbs Up
Post #169293 1st Feb 2013 10:29am
T111RDY
Scotland 2002 Range Rover Vogue 4.4 V8 Java Black
I'm doing mine tomorrow!
Good luck! l:OolΞΞΞΞΞΞloO:l
2002 4.4 Vogue Java Black
Post #169308 1st Feb 2013 11:16am
wiki
http://www.fullfatrr.com/gallery/thumbnails.php?album=359 .
Post #169320 1st Feb 2013 12:39pm
comports
Good luck also T111RDY..!
We'll share stories Saturday pm (hopefully) after it's all done.! Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #169335 1st Feb 2013 2:25pm
Brewster
England 2006 Range Rover Vogue SE TDV8 Buckingham Blue
I did mine a couple of months ago, took less than an hour with two of us, my friend had done several before. Would advise having the means to support the hub either blocks of wood or another jack. Oh and you're gonna need a GOOD breaker bar because Jeez are those bolts tight !!
Good luck Thumbs Up ...Always time for a brew !!
2006 TDV8 Vogue SE
Post #169365 1st Feb 2013 5:31pm
comports
Early update...
Got home - had tea - got impatient so thought I'd put the car up on axle stands, remove the wheels and squirt in penetrating fluid ontp the bolts and let them do their stuff ready for a 9am start...
Well - got even more impatient and got 600mm socket lever out and all four lower bolts turned (with a bit of effort)..!!
Left it there for tonight but it seems the really hard part may not be so hard after all.
(Now I've just jinxed the rest of the job) Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #169436 1st Feb 2013 10:48pm
goldsax
United Kingdom 2011 Range Rover Vogue 4.4 V8 Ipanema Sand
how much were the struts? 2011 4.4 TdV8 Nara Bronze
Post #169442 1st Feb 2013 11:28pm
comports
Dan from Duckworths has them for £225 plus VAT Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #169444 1st Feb 2013 11:32pm
goldsax
Thumbs Up 2011 4.4 TdV8 Nara Bronze
Post #169465 2nd Feb 2013 9:31am
comports
Final update from me.....
ALL DONE - And actually quite pleased with myself. Didn't struggle too much but would have been easier with 2 people. approx 1 hr per corner.
Daunting moment was turning the car on once it was back on the ground but all four corners rose and sat nice and level. Went for a test (actually down the dump to take the old suspension away) and all was fine so job well done.!
Thanks for you guidance. Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #169552 2nd Feb 2013 4:41pm
So no calibration needed then? Previously..
Post #169558 2nd Feb 2013 4:59pm
comports
Not as far as I know. Turned the car on and it all kicked into life.
Did take a while to rise but I guess that's because I used the IID to empty the corners prior to doing the job.
I did incidentally configure park/exit mode to be 15mm lower than standard and was amazed at how much easier it is to get/out when down. Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #169575 2nd Feb 2013 6:14pm
I suppose as long as the height sensors are not touched there is no reason why it would need calibrated? It would just inflate until it reached the point the sensor says stop.
As for easy entry/exit, that's why god invented side steps! Thumbs Up Previously..
Post #169583 2nd Feb 2013 6:38pm
comports
I have them aswell but always found I'm squashing the side bolster of the seat.. I've probably just got short legs..!! Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #169587 2nd Feb 2013 7:00pm
