Home > Maintenance & Mods (L322) > Replacing sidelight bulbs with LED's
My FFRR is the MY2006 facelift. I got fed up looking at the yellow bulbs in the sidelights, they looked out of place next to the white headlights. So I have eventually gotten round to changing them to error free LEDs. I bought some then someone posted about a better type, so I bought them. The shorter ones I will use somewhere else, the longer ones are the type I fitted.
I have light guards fitted. 4 screws and off they come.
These blocks are screwed onto the wing. Thankfully plastic so no rust worries.
Next remove the front grill. There are 3 bolts along the top to remove then the grill just lifts up.
Watch out for the temperature sensor behind the badge on the grill. It just unclips.
The headlight is now exposed.
Unscrew the 2 screws at the top of the headlight
And unscrew the 1 at the bottom
The headlight is now loose and can be moved forward or removed. To remove, unclip the wiring connector.
Twist off the lower round cover to expose the sidelight bulb.
The bulb just pulls out of its holder.
Replace with the new led. It's best to switch the sidelights on to make sure the bulb has been fitted the correct way round. If it does not light, just turn it round. Push it back into its hole.... Remember to put the round cover back on ! Whistle
Refitting is just the reversal of the above. The headlights will go back in the same place, so no need to worry about alignment. Remember to clip the temp sensor back in.
The finished result.
I wish I had done it earlier now. This must be one of the cheapest and most effective mods for the FFRR.
Go do it now ! :thumbsup:
Post #169632 2nd Feb 2013 9:13pm
E4 GUY
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
I did exactly the same today. best £5.99 spent ! i got my 4 year old to hold the bulbs so I didnt even need to disconnect the wires Smile Alcohol and eBay is never a good mix
2006 4.2 Supercharged, Java Black
Post #169649 2nd Feb 2013 11:01pm
wackyjim
Scotland 2011 Range Rover SE TDV8 Santorini Black
Looks good Thumbs Up
Post #169651 2nd Feb 2013 11:02pm
E4 GUY
before
after
much better:
Post #169657 2nd Feb 2013 11:23pm
Post #169658 2nd Feb 2013 11:25pm
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
Damn it! The more I see you guys with the LED lights the more I want them, but I'm too lazy ...
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #169659 2nd Feb 2013 11:28pm
E4 GUY
nine screws....15 mins max Alcohol and eBay is never a good mix
Post #169661 2nd Feb 2013 11:29pm
TheAllSeeingPie
Yeah but once I get started I'll want to do the halogen fill-in lights and interior ...
Post #169662 2nd Feb 2013 11:32pm
TASP I've bit the billet and ordered some Smile for me it means I will be cooking my lights though Sad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #169672 3rd Feb 2013 12:53am
Googsy
Easy to do just ensure you put it in at 120 if using a fan oven for 8 mins. Make sure lught doesn't touch of sidof oven.put it on a pizza tray coverd in a tea towel. Make sure you remove all bulbs ad ballast before cooking Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #169678 3rd Feb 2013 2:02am
have done this too - looks awesome Smile All my spelling errorz are belong to me!
2024 RR Velar
2021 AM new Vantage
Post #169694 3rd Feb 2013 10:28am
Worth noting that some LED bulbs only work if the polarity is the right way around, so before re-fitting the headlamps check both sidelights work... Whistle
Craig Thumbs Up
Post #169698 3rd Feb 2013 10:32am
^ I did say that! Switch lights on to check bulbs work, if not turn them round! Previously..
Post #169702 3rd Feb 2013 10:45am
Saint.v8
Location: UK< Surrey - Near the Middle Close to Some Green Bits
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Grand write up....may just have to do this myself...as you say the yellow incandescents look odd next to the whiter Xenons!
Post #169713 3rd Feb 2013 12:07pm
Paulhh
Scotland 2002 Range Rover Vogue 4.4 V8 Epsom Green
Did it this morning, much better Thumbs Up 2002 Vogue Epsom Green with Ivory Leather.
Discover 2 V8
Discovery 2 TD5
Discovery 1 V8
Audi S4 (2005)
Audi S4 (2000)
Post #169723 3rd Feb 2013 1:28pm
