![]() | Home > Technical (L322) > Doom and Gloom |
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 ![]() ![]() ![]() |
I'd double check what you can hear first - a big end will knock at idle and often either go away or get (much) worse under load.
Paulhh Member Since: 23 Dec 2012 Location: Carrbridge Posts: 143 ![]() ![]() ![]() |
Cheers for that.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35837 ![]() ![]() |
could it be your vanos?
I'll investigate that route right away, I did get an impression it was from the head but the noise sounded like something I had heard many years ago and it was a crank bearing.
If you can't hear it with the acoustic covers in place, it can't be that serious! |
After Stan mentioned the Vanos, I found someone had put a video on utube and it does sound the same. His noise he could still hear with the covers on.
No.
It's worth noting that the BMW engine is almost a throw-away item. I looked at this a while back for a cheap 4.4 I was considering. That one had a blown engine.
I certainly feel happier with all the advice.
Rave says:
Simes
Actually it's bloody freezing up here in the Highlands so maybe 5/40 would be fine in these temps? |
I'd stick with Rave - as you say, at this time of year all oil is as thick as grease! |
just a headsup, eurocarparts are offering 25% of castrol oils at the moment using code OIL25.. ... - .- -.
