![]() | Home > Maintenance & Mods (L322) > Suspension seems slower to raise after changing front struts |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1763 ![]() ![]() ![]() |
Now it may just be my imagination but since changing the suspension last weekend the car seems to take longer to stop flashing when rising. It may be due to the cold weather and I didn;t notice it before or it may be that the new airbags need time to "settle in" or it may be something else.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35827 ![]() ![]() |
check the connections Ash, there might be a leak..new rubber might be stiffer so the compressor will have to work just a little harder, or your 'lowering' could be affecting the inflation duration.. ... - .- -.
Thanks Stan - The problem is to check the connection (ie air line to the bag) it means taking the whole lot out again doesn't it.?
you could probably hear any leaks , a slight hissing would point in the right direction..
inflation duration (snigger...... don't know why?) |
i was gonna say 'inflation duration across the nation' but rapping isnt my style... |
