Home > Maintenance & Mods (L322) > Suspension seems slower to raise after changing front struts
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Now it may just be my imagination but since changing the suspension last weekend the car seems to take longer to stop flashing when rising. It may be due to the cold weather and I didn;t notice it before or it may be that the new airbags need time to "settle in" or it may be something else.
Is there a set amount of time it should take to rise from access height to standard..
Actually this may be a silly question seeing as I also lowered the access height by 15 - 20mm..!!! Shocked
Am I just stupid... is it obvious that it needs to put more air in now that it has to raise further.?
I think I answered it myself...... I assume it wont do any damage by running the compressor for longer nowadays..
EDIT - Ignore my ramblings (unless you think there is a different issue) Very Happy Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #170857 7th Feb 2013 11:17pm
check the connections Ash, there might be a leak..new rubber might be stiffer so the compressor will have to work just a little harder, or your 'lowering' could be affecting the inflation duration.. ... - .- -.
Post #170883 8th Feb 2013 9:25am
comports
Thanks Stan - The problem is to check the connection (ie air line to the bag) it means taking the whole lot out again doesn't it.?
That's a pain. Should I pump it up to off road, measure it (arch to rim), leave it over night and check again.? Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #170893 8th Feb 2013 10:33am
you could probably hear any leaks , a slight hissing would point in the right direction..
certainly a series of access to off road might settle the system.. ... - .- -.
Post #170904 8th Feb 2013 11:28am
inflation duration (snigger...... don't know why?) Smile .
Post #170944 8th Feb 2013 1:40pm
i was gonna say 'inflation duration across the nation' but rapping isnt my style... Mr. Green ... - .- -.
Post #170946 8th Feb 2013 1:43pm
