Home > In Car Electronics (L322) > Bluetooth connector leads/plug
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Hi All,
Searched but can;t find what I need. Basically I have the 7th Gen Bluetooth unit, microphone and arial (I think) so I believe all I need is the custom lead to plug it all together.
Any idea where I can get such a lead or a new lead that might need re pinning.? (with part number preferably)
I'm sure I've seen a guide to re pinning on here somewhere. Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #171731 12th Feb 2013 3:32pm
is this what you need Ash,
http://www.disco3.co.uk/gallery/albums/use...date~1.pdf ... - .- -.
Post #171735 12th Feb 2013 3:37pm
comports
Thanks Stan but no.
I don't have any phone in the car yet but it is pre wired to take it. I have a large white 54(?) pin plug in the rear left which apparently is for the phone. It's from that plug to the bluetooth unit that I need. Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #171743 12th Feb 2013 3:52pm
dirtyharry
Start by having a read of this post and all the links in it; I did and found the answers to all my questions Thumbs Up
Unless you buy the Audi convertor/connector, you'll need to re-pin the existing 54 pin connector in your boot (which is what I did).
mjdronfield is an expert on this topic. I wouldn't have got mine installed without his help Bow down
http://www.fullfatrr.com/forum/topic14122....=bluetooth Cheers
Greg
Go ahead punk, make my day........
Previous vehicles:-
Far too many to list (in excess of 45!)
Post #171809 12th Feb 2013 7:32pm
comports
Thanks Greg
It appears I only have the large 12 pin white female plug in the boot space after all and not the black 54 pin end.
Does this mean ill need the plug you got from audio? Assume it has the male 12 pin end (that needs the re pinning) and the other end is the 54 pin that connects directly to the ULF unit?
Thanks Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #171834 12th Feb 2013 8:45pm
dirtyharry
I'm not sure it's as simple as that, if you haven't got the 54 pin connector. Have you checked way down in the depths of the boot on the left hand side? If there is one it's usually buried! Either way, I think you'll have to do some re-pinning - but I'm sure someone on here will correct me if I'm wrong.
Also, if you haven't already, check to see you have a 3-pin connector for the microphone (it's in the overhead console behind a small black cover - it was a yellow wire if I remember correctly).
And I assume you've got "Telephone" as an option on your TV/Nav display (albeit it will be "greyed out", until the ULF module is installed when it will become active)?
There's something in this post about the 12-pin connector - it might help.
http://www.fullfatrr.com/forum/topic9783.html?highlight=ulf
.....this might be the connector you need (I already had the 54-pin connector so I didn't need it)
http://www.fullfatrr.com/gallery/albums/us...wiring.pdf
If you do a search for ULF and/or bluetooth you'll find loads of threads which will help. Cheers
Greg
Previous vehicles:-
Post #171849 12th Feb 2013 9:29pm
mjdronfield
Did you get any further ?
Greg is right, in that its a bit harder if your car is not wired for phone. Its listed as "Personal Telephone Integration (PTI)" if you get a printout of the build sheet for your car from a dealers.
Its not impossible without the prewire - its just that you'll have to run cables from the rear of the car to the front for the microphone.
RAVE should detail the electrical connections, so you may be able to trace the 12 or so wires you actually need for the ULF from whatever plugs are in the boot.
I did not have Telephone displayed on my screen at all, until the ULF was connected up and recognised on the ibus.
Also without the prewire, you will need the aerial lead that goes from the ULF to the bluetooth aerial,........
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #172660 16th Feb 2013 12:41pm
comports
HI MJ
The only bit left for me to do is source the plug from the white loom to the ulf unit. I believe the car is pre wired but missing this plug/loom. Mic is there and arial etc...
No idea where to get this part yet but working on it.!
If anyone has the plug but is not using the ulf (or does not have one) I'd be happy to purchase the last part of the loom..! Very Happy Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #172702 16th Feb 2013 4:45pm
