Home > In Car Electronics (L322) > Aftermarket?
broncoupe
Are you using the pioneers inbuilt amp or are you going to run a separate amp in the boot?
Post #172083 13th Feb 2013 8:42pm
SATVC
United Kingdom 2004 Range Rover Vogue Td6 Java Black
Ill defo be fitting two amps, I'm tempted to rewire the door with new speakers but if I can pick up the speaker wires in the rear it would make life easier as I can keep the original speakers for a bit? I'll run a 4 channel amp to the doors, and a mono to a new custom sub box mounted in original position!
Well that's the plan Whistle
Post #172084 13th Feb 2013 8:50pm
SteveyD
England 2003 Range Rover Vogue Td6 Bonatti Grey
Got the screen working yet? My nav disc player is faulty and if I have a disc in it nothing else works on my audio and the player screen goes blank but backlit. I wrestle with the player to give up the disc, turn my car off & on and everything's back to normal.
I use my iPhone nav now, I'm not overly bothered about nav or tv etc. I was going to remove every single bit of the OEM install and go down the aftermarket route, it's tempting because of the features most new units have but I decided to pass on the idea because I didn't want to loose my on board computer.
Post #172097 13th Feb 2013 9:15pm
SATVC
Ill be gutted to lose the mpg as it makes me drive easier! But the clock will be on the new double din!
Those I can do without for better sound quality/iPod/sub bass etc!!
Post #172101 13th Feb 2013 9:18pm
SteveyD
You could relocate your screen to your glovebox and would still have the display below your clocks, someone here has done exactly that. the slightly dated audio has grown on me now though Razz
Post #172111 13th Feb 2013 9:30pm
SATVC
I've seen that, it's a great idea but I have a blank screen so can't see anything anyway!
Post #172116 13th Feb 2013 9:44pm
@ SATVC
Check out the pin assignments on the BM54 radio for speaker connections
Post #172122 13th Feb 2013 9:58pm
SATVC
Ooooohhhhhh joe
Thankyou!!! That's perfect!
Only thing that only Shows 4 speakers (unless they split off to each speaker in each door?)
Post #172124 13th Feb 2013 10:01pm
SteveyD
Joe is definitely your audio guru.
Did you get the disc out of your nav unit, or was it never stuck?
Can you see mpg etc on your high line display?
Post #172132 13th Feb 2013 10:14pm
SATVC
I can take disc in and out fine!! Dash display is fine! Radio and cd changer work ok! I just have no display on the screen to change anything!
When I disconnect the sat unit compleatly the music turns off after a minute or so, I then have to turn off then back on the left round button to get another minute of music??
When I connect the sat unit straight to the tuner (blue plug) still no screen.
Also front door speakers are failing! Turning on and off intermittently?
Post #172138 13th Feb 2013 10:20pm
SATVC
One of the members on here has provided me with this link!
What a great find, thanks so much!
http://www.xoutpost.com/miscellaneous/subm...ement.html
And a list of wire colours for speakers
Post #172179 14th Feb 2013 12:11am
broncoupe
Remember the amp is active this means if you keep the original speakers they will need simple crossovers or bi amp wiring, as the factory amp did this originally.
Post #172194 14th Feb 2013 7:11am
broncoupe
Used to do this on BMW X5s quite a lot with Genisis Amps results used to be quite good just lacked a bit of Bass
Post #172195 14th Feb 2013 7:14am
SATVC
That's cool, I need a 2x 3way passive x overs for the front and 2x 2 ways for the rear door speakers!
The plan is now coming together!
Post #172198 14th Feb 2013 8:36am
