![]() | Home > In Car Electronics (L322) > Aftermarket? |
broncoupe Member Since: 21 Nov 2011 Location: bournemouth Posts: 70 ![]() |
Are you using the pioneers inbuilt amp or are you going to run a separate amp in the boot? |
SteveyD Member Since: 11 Dec 2012 Location: Cheshire Posts: 352 ![]() ![]() ![]() |
Got the screen working yet? My nav disc player is faulty and if I have a disc in it nothing else works on my audio and the player screen goes blank but backlit. I wrestle with the player to give up the disc, turn my car off & on and everything's back to normal.
SATVC Member Since: 25 Nov 2012 Location: Surrey Posts: 172 ![]() ![]() ![]() |
Ill be gutted to lose the mpg as it makes me drive easier! But the clock will be on the new double din!
You could relocate your screen to your glovebox and would still have the display below your clocks, someone here has done exactly that. the slightly dated audio has grown on me now though |
I've seen that, it's a great idea but I have a blank screen so can't see anything anyway! |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
@ SATVC
Ooooohhhhhh joe
Joe is definitely your audio guru.
I can take disc in and out fine!! Dash display is fine! Radio and cd changer work ok! I just have no display on the screen to change anything!
One of the members on here has provided me with this link!
Remember the amp is active this means if you keep the original speakers they will need simple crossovers or bi amp wiring, as the factory amp did this originally. |
Used to do this on BMW X5s quite a lot with Genisis Amps results used to be quite good just lacked a bit of Bass |
That's cool, I need a 2x 3way passive x overs for the front and 2x 2 ways for the rear door speakers!
