![]() | Home > General > New FFRR owner with more questions |
mikef Member Since: 30 Jan 2013 Location: Bucks Posts: 82 ![]() ![]() ![]() |
Thanks to all who replied to my first post here http://www.fullfatrr.com/forum/topic16395.html
E4 GUY Member Since: 07 Jan 2013 Location: London Posts: 513 ![]() ![]() ![]() |
1) Turn off TMC by pressing the "info" button, under the main power knob
SteveyD Member Since: 11 Dec 2012 Location: Cheshire Posts: 352 ![]() ![]() ![]() |
TMC gets on my |
Don't even touch it! Just call LRA out and get them to do it |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35841 ![]() ![]() |
luckily you have a warranty on yours Mike , so like Will has suggested get landrover to sort that for you.... ... - .- -.
Phoned local dealer to book car in for low coolant warning and they just said top the reservoir up with domestic water which I did and hey presto, warning light gone. Bit worrying still that alarm came up so soon after taking delivery but I'll have to see whether it happens again.
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6381 ![]() ![]() |
TPMS - Pray to the Gods you don't have it, but check your tyre valves, if they are made of metal, short and stubby and look like a bolt head its got TPMS. If it is just a standard rubber tyre valve, its not.
Rolo Member Since: 11 May 2011 Location: UK Posts: 852 ![]() ![]() ![]() |
The timed climates have been known to be a bit useless on 2010 onwards. Some have problems where they won't heat at all, or if any heat, only a barely warm cabin. If the battery is a little low they won't come on to save the drain problem |
Thanks. OK I'm praying on the TPMS. What I don't understand though is that on previous cars I've had with TPMS, you have to confirm that the tyre pressures are correct through one of the screen menus but I can't find any reference to TPMS on any menu I've found on my FFRR. Yes I have the remote key fob for the timed climate and that seems to work |
Thanks, I'll try that. At the moment its set to my normal setting of 21 deg |
My pre heat warms the cabin no matter what setting my temp controls are.
