Home > General > New FFRR owner with more questions
mikef
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Zermatt Silver
Thanks to all who replied to my first post here http://www.fullfatrr.com/forum/topic16395.html
I have now had my new (to me) Vogue SE for a few days and I'm very happy with it but I've got a couple more questions to ask
1. How on earth do I turn the TA traffic announcements off? They're driving me nuts
2. Does the satnav screen dim automatically at night? How do I know if mine does as it seems very bright even though I've turned the brightness adjuster down
3. How do I stop the rear parcel shelf creaking?
Post #171590 12th Feb 2013 12:02am
E4 GUY
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
1) Turn off TMC by pressing the "info" button, under the main power knob
2) Page 99 of manual says the dial down by lights adjusts all dash instrumentation "forward of the driver..."
Page 282 suggests that you may want to use "set 1" for daytime and "set 2" with brightness turned down for night?
No explicit mention of auto dimming.
{Edited: you found Screen brightness ! } Embarassed
is under main home menu, settings, screen settings.
Press the "tick" button on top left hand side
3) not covered in manual ... Laughing Alcohol and eBay is never a good mix
2006 4.2 Supercharged, Java Black
Post #171594 12th Feb 2013 12:19am
SteveyD
England 2003 Range Rover Vogue Td6 Bonatti Grey
TMC gets on my Censored 's
Post #171597 12th Feb 2013 12:55am
mikef
Thanks E4GUY. Thats solved the TA problem. Yes I found the brightness adjuster but I dont remember seeing set 1 and set 2. I'll have to look at the manual. Btw I think the manual is s**t or at least the index is. There is no reference in the index to 'traffic announcement', 'brightness adjustment' or 'auto dimming'. This is poor considering the L322 has been in production for 10yrs
PS First problem of FFRR ownership has arisen this morning. Low Coolant alarm has appeared on the dashboard. Tried stopping/starting ignition but it's still there. I guess I'll actually have to check the coolant level when the engine cools down. This is a new experience for me as German cars don't do this but I expect that FFRR is a different kind of ownership proposition
Post #171648 12th Feb 2013 11:08am
Don't even touch it! Just call LRA out and get them to do it Smile
As for the creaking rear panel some people fit some slithers of felt i believe down the runners and that sorts it out Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #171655 12th Feb 2013 11:59am
luckily you have a warranty on yours Mike , so like Will has suggested get landrover to sort that for you.... ... - .- -.
Post #171667 12th Feb 2013 12:36pm
mikef
Phoned local dealer to book car in for low coolant warning and they just said top the reservoir up with domestic water which I did and hey presto, warning light gone. Bit worrying still that alarm came up so soon after taking delivery but I'll have to see whether it happens again.
Apologies but I have 3 more questions
1) How do I know whether my car has got a tyre pressure monitoring system because I can't find any reference to it in the dashboard menus?
2) Have tried using the Timed Climate facility. A whirring noise starts somewhere under the bonnet but the interior doesn't seem to warm up at all. Is it supposed to? If not, what does Timed Climate do?
3) How do I connect an Ipod to the socket in storage locker between the seats? What kind of cable is it?
Post #172176 13th Feb 2013 11:56pm
TPMS - Pray to the Gods you don't have it, but check your tyre valves, if they are made of metal, short and stubby and look like a bolt head its got TPMS. If it is just a standard rubber tyre valve, its not.
Have you got the remote control keyfob for pre heating?
Ipod connectivity should just be a standard ipod cable Discovery 4 HSE
1993 90 Tdi
Post #172208 14th Feb 2013 9:34am
Rolo
United Kingdom 2012 Range Rover Vogue SE TDV8 Orkney Grey
The timed climates have been known to be a bit useless on 2010 onwards. Some have problems where they won't heat at all, or if any heat, only a barely warm cabin. If the battery is a little low they won't come on to save the drain problem Rolling Eyes
Check that you have left the heater on quite hot & on "Auto" setting before you turn the engine off & lock up for the night, then give it another go in the morning.
I found mine works best if left on about 26 degrees on the temp guages.
Post #172226 14th Feb 2013 10:58am
mikef
Thanks. OK I'm praying on the TPMS. What I don't understand though is that on previous cars I've had with TPMS, you have to confirm that the tyre pressures are correct through one of the screen menus but I can't find any reference to TPMS on any menu I've found on my FFRR.
Yes I have the remote key fob for the timed climate and that seems to work
Post #172231 14th Feb 2013 11:19am
mikef
Thanks, I'll try that. At the moment its set to my normal setting of 21 deg
Post #172232 14th Feb 2013 11:20am
My pre heat warms the cabin no matter what setting my temp controls are.
One thing to note is that often when you start up afterwards its knocks off the air con button. Discovery 4 HSE
1993 90 Tdi
Post #172267 14th Feb 2013 2:09pm
