Home > Technical (L322) > New owner big problem (I think)
RugbyXV
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Baltic Blue
Hi, Very raw Newbie here..
I am both new to range rovers and new to the forum which to be honest I didn't I'd need quite so quickly! Less than a month of ownership. Lovely car when working, need I go on??
I have a 2003 4.4 L322 Vogue, a week ago it started and stopped immediately giving a cam sensor fault. Got recovered, replaced the sensor still wouldn't start. Had the three requirements, spark fuel and compression but no go. It does have a LPG conversion.
So, off to an independent LR garage and they have just told me they're stumped too...when they turn over there is no power to the pump yet when they jump the pump it works fine. No codes and all fuses and relays are OK and the T4 says everything fine. Mechanic stepped away today to halt his suicidal tendencies I believe..If we're all at a loss, can anyone here help before both I and my mechanic do something silly?
Post #172303 14th Feb 2013 5:13pm
me thinks the lpg conversion might be telling the petrol fuel pump to be off....can you disconnect the lpg and see what happens.. ... - .- -.
Post #172304 14th Feb 2013 5:16pm
Jonno
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Causeway Grey
I'd say the same as stan, remove the lpg main fuse. The fault will be with the lpg ecu/emulator. 5.0 supercharged autobiography
Gone-4.4 Vogue Lpg now unmapped
4.6 HSET Turbo Lpg mapped
Gone-Defender 90 200tdi
Gone - 3.9 Sprintex supercharged LPG
Gone - 3.9 Vogue LPG
Post #172342 14th Feb 2013 7:57pm
RugbyXV
Thanks for your help.
Forgive my ignorance, but my understanding was that LPG only isolated the injectors, not the fuel pump. Am I right in this assumption?
I'm going to phone the garage and ask them to isolate the LPG and see what happens, after a week I'd try anything to be honest before I get to the rag in filler neck!!!
Post #172434 15th Feb 2013 10:43am
i cant see the petrol fuel running when you are on lpg, it will just burn out... ... - .- -.
Post #172436 15th Feb 2013 10:45am
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Quick question from me....
Should you not go back to the garage that sold you the car and politely ask them to fix it.?
(apologies if you bought privately however) Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #172441 15th Feb 2013 10:54am
RugbyXV
The warranty blurb has been quoted to me as "repair of faulty items" at this moment in time it is classed as a breakdown and until the fault is found the warranty is ineffective....check your warranties if you have them!
My car has not started for 3 weeks as of today. It has been with an indey for 10 days and they are still none the wiser. Not their fault as there are no fault codes to go by. This is the latest update.
Power to the fuel pump when key at position 2, no power when turned to starter position but the engine turns. The pump is ok when powered up by a battery, but again, when that power is taken off it all reverts to above. Everyone is now really scratching their heads. The T4 software outfit don't have a clue and they have been on to LR at Gaydon with similar response. They are now stripping the electrical system down I believe. If anyone can help I would be eternally grateful. Not a good experience from a 4 week ownership perspective but love the car when it was running... Big Cry
Post #173641 20th Feb 2013 7:21pm
cliffy
2004 Range Rover Vogue 4.4 V8 Zambezi Silver
is ur indy any good with lpg?
If everything works till the ignition starts id be saying lpg causing a issue
Post #173643 20th Feb 2013 7:38pm
bozmandb9
2013 Range Rover Vogue SE TDV8 Causeway Grey
Have you tried forcing it to start on LPG? This will help indicate if its a fuel pump problem. Can't help you with how to start on LPG, depends on the LPG kit, either refer to instructions, or google for answer. Good luck! Thumbs Up 2012 SDV8 Vogue SE
Post #173648 20th Feb 2013 8:35pm
How experienced is your indy on FFRR's rather than old Landrovers ?
I'd be inclined to talk to JE Engineering in Coventry and see if they'll look at it.
Post #173649 20th Feb 2013 8:45pm
Deasy
What Indy have you taken it to?? MRM in Coventry are good with landys, and a good price?
I'm in rugby too Thumbs Up
Post #173650 20th Feb 2013 8:50pm
To start on LPG with my system I have to press and hold the LPG switch over button then turn the key. Not the best but might get it going. Also could you not disconnect the LPG ECU and re connect to the cars normal ecu? They are usually piggy back ecu's if you understand what I mean.
Try giving this guy Andy Evans a call 0151 639 1555 he's a really good installer and will give you as much help as he can. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #173663 20th Feb 2013 10:43pm
so has the lpg system been disconnected like my suggestion in the second post.. ... - .- -.
Post #173669 20th Feb 2013 11:01pm
Have you Contacted a lawyer? I would. I would be parking the car back at the garage and asking for my money back. Previously..
Post #173674 20th Feb 2013 11:15pm
Stan, the fuel pumps always run (the same as if running on petrol) which is why so many problems arise from running an LPG car with very low petrol levels for a long distance... Thumbs Up
Post #173692 21st Feb 2013 12:36am
