Home > Technical (L322) > Fuel Burning Heater - On an 06 MY Supercharged?
PNR
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
Just obtained my new transport, a beautiful 06 MY Supercharged Vogue SE RR.
Reading through the manual i understand the facility of a FBH and the remote control for it (to warm the car from the comfort of the home).
Without removing panels / getting technical with the car less than two days after owning, could you tell me whether or not it's likely it would be fitted with the FBH and what i would need to do to get it working (presuming remote isn't hidden somewhere in the car already).
Cheers
PNR 06 Range Rover Supercharged
05 Discovery 3 SE
Post #17286 23rd Apr 2010 1:41pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
The onboard computer will have timer settings for an FBH if fitted. If it's not fitted, the options are not there....it actually IS that simple Smile
The onboard computer being the touchscreen unit in the middle of the dash Whistle
Oh for an SC to have one, it will have been ordered on the original build, they are fairly uncommon (although I know of 2!) Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #17287 23rd Apr 2010 1:43pm
FBH's are 99% for the Diesel FFRR's , having an SC it's very unlikely to have one on that .......
Post #17289 23rd Apr 2010 1:52pm
VaguelyVogue
United Kingdom 2006 Range Rover Vogue Td6 Buckingham Blue
The search function is your friend - have a look for FBH !
The thread here explains most of it http://www.fullfatrr.com/forum/topic1324.h...p;start=15
Post #17295 23rd Apr 2010 2:58pm
VMPP
Portugal 2007 Range Rover Vogue TDV8 Buckingham Blue
From what i've read in the other forum, all diesels come fitted with the FBH. But the software either is enabled or not. If you have a diesel, then you can have the dealer enable you the system. Then all you need to do is buy the remotes for the system.
On a petrol, that's a whole different story... They don't come fitted as standard from the factory. Then you have to buy a ''webasto'' fit it to the car, buy the remotes, fiddle with the systems, etc...
Post #17301 23rd Apr 2010 3:57pm
They all have the on screen controls for recirculating the air, doesn't mean its connected to a FBH though. Discovery 4 HSE
1993 90 Tdi
Post #17303 23rd Apr 2010 4:03pm
DMRR
They don't - well the 2006+ SC's don't, which is what this thread is about Wink Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #17305 23rd Apr 2010 4:05pm
I thought they all had the option to circulate the air with no other magic behind i.e. air con or FBH? Discovery 4 HSE
1993 90 Tdi
Post #17307 23rd Apr 2010 4:09pm
DMRR
The BMW built ones did, then when the new MOST system arrived, that all went, along with PIN locking etc etc ....
My 4.4 BMW built one had the screen you are referring to, and the ability to time it to blow outside temp air, but that was all.
The newer models now react to what is physically fitted. Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #17308 23rd Apr 2010 4:12pm
daveo
i thought aswell, petrols dont have them, i was told they are a diesel burning unit...full stop..i have the ventilation option with timer in my menu but this only circulate air from out side to call down the cabin. V8 facelift Range Rover Autobiography 22" wheels.
Post #17315 23rd Apr 2010 4:33pm
DMRR
Daveo,
Is yours touch screen? Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #17317 23rd Apr 2010 5:00pm
PNR
All, Thanks for the responses. Have definitely confirmed by checking system settings that i don't have it.
BTW - i did search previous topics for answer but not conclusive that you couldn't spec the car (even a petrol) with the FBH. 06 Range Rover Supercharged
05 Discovery 3 SE
Post #17585 28th Apr 2010 1:05pm
