![]() | Home > Technical (L322) > Fuel Burning Heater - On an 06 MY Supercharged? |
The onboard computer will have timer settings for an FBH if fitted. If it's not fitted, the options are not there....it actually IS that simple |
FBH's are 99% for the Diesel FFRR's , having an SC it's very unlikely to have one on that ....... |
VaguelyVogue Member Since: 05 Feb 2010 Location: Buckinghamshire Posts: 380 ![]() ![]() ![]() |
The search function is your friend - have a look for FBH !
VMPP Member Since: 12 Jul 2009 Location: Lisboa Posts: 412 ![]() ![]() ![]() |
From what i've read in the other forum, all diesels come fitted with the FBH. But the software either is enabled or not. If you have a diesel, then you can have the dealer enable you the system. Then all you need to do is buy the remotes for the system.
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6374 ![]() ![]() ![]() |
They all have the on screen controls for recirculating the air, doesn't mean its connected to a FBH though. Discovery 4 HSE
They don't - well the 2006+ SC's don't, which is what this thread is about ![]() XXXXXXXXXXXXXXXXXXXXXXX Previous XXXXXXXXXXXXXXXX 2009 5.0V8SC Autobiography 2006 4.2V8SC Autobiography 2004 4.4V8 Vogue |
I thought they all had the option to circulate the air with no other magic behind i.e. air con or FBH? Discovery 4 HSE
The BMW built ones did, then when the new MOST system arrived, that all went, along with PIN locking etc etc ....
i thought aswell, petrols dont have them, i was told they are a diesel burning unit...full stop..i have the ventilation option with timer in my menu but this only circulate air from out side to call down the cabin. V8 facelift Range Rover Autobiography 22" wheels.
Daveo,
PNR Member Since: 23 Apr 2010 Location: Cheshire Posts: 2 ![]() ![]() ![]() |
All, Thanks for the responses. Have definitely confirmed by checking system settings that i don't have it.
