![]() | Home > Technical (L322) > New owner big problem (I think) |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35801 ![]() ![]() |
interesting, i wonder if the lpg 'switch the petrol fuel pump off' part has been disconnected properly cos i still think its somehow affecting the power to the petrol fuel pump.. ... - .- -.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16392 ![]() ![]() ![]() |
If I were in your shoes I would take the car away today my friend... In the wrong hands a lot of damage/problems can occure... A problem like yours isn't hard to diagnose when you have experience... And are good at your job ![]() |
but OP says that ''when they turn over there is no power to the pump yet when they jump the pump it works fine.'' ..or am i not understanding this properly... ... - .- -. Y. O. L. O. . |
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1055 ![]() ![]() |
I agree with Craig, if they've made no real progress over three weeks, get it picked up right away, and take it to somebody else!
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8090 ![]() ![]() ![]() |
Agree - at this point, they can't be doing meaningful analysis, they must be down to randomly unplugging things to see what happens. |
RugbyXV Member Since: 14 Feb 2013 Location: Rugby Posts: 42 ![]() ![]() ![]() |
Hi,
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
Have you actually had fuel out the engine end? If the pump is running the LPG could be stopping the injectors firing? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
The LPG has been completely disabled so I don't think that will be the cause, it is purely a petrol V8 at the moment. |
ther vwas something on the forum re if you had less than a quarter tank of fuel it would cause running problems...just a shot in the dark but check the fuel level... ... - .- -.
