![]() | Home > Technical (L322) > New owner big problem (I think) |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35801 ![]() ![]() |
me thinks the lpg conversion might be telling the petrol fuel pump to be off....can you disconnect the lpg and see what happens.. ... - .- -.
Jonno Member Since: 08 Jun 2011 Location: Eastnor HR8 Posts: 191 ![]() ![]() ![]() |
I'd say the same as stan, remove the lpg main fuse. The fault will be with the lpg ecu/emulator. 5.0 supercharged autobiography
RugbyXV Member Since: 14 Feb 2013 Location: Rugby Posts: 42 ![]() ![]() ![]() |
Thanks for your help.
i cant see the petrol fuel running when you are on lpg, it will just burn out... ... - .- -.
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1762 ![]() ![]() ![]() |
Quick question from me....
..... Should you not go back to the garage that sold you the car and politely ask them to fix it.? (apologies if you bought privately however) Ash ------------------------------------------------------ 2022 SDV8 AB 2016 TDV8 VSE 2011 TDV8 VSE 2006 V8 Vogue 2002 2.5 Vogue |
The warranty blurb has been quoted to me as "repair of faulty items" at this moment in time it is classed as a breakdown and until the fault is found the warranty is ineffective....check your warranties if you have them!
cliffy Member Since: 17 Apr 2010 Location: Surrey Posts: 556 ![]() ![]() |
is ur indy any good with lpg?
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1055 ![]() ![]() |
Have you tried forcing it to start on LPG? This will help indicate if its a fuel pump problem. Can't help you with how to start on LPG, depends on the LPG kit, either refer to instructions, or google for answer. Good luck! |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8090 ![]() ![]() ![]() |
How experienced is your indy on FFRR's rather than old Landrovers ?
Deasy Member Since: 26 Oct 2011 Location: Warwickshire Posts: 210 ![]() ![]() ![]() |
What Indy have you taken it to?? MRM in Coventry are good with landys, and a good price?
To start on LPG with my system I have to press and hold the LPG switch over button then turn the key. Not the best but might get it going. Also could you not disconnect the LPG ECU and re connect to the cars normal ecu? They are usually piggy back ecu's if you understand what I mean.
so has the lpg system been disconnected like my suggestion in the second post.. ... - .- -.
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700 ![]() ![]() |
Have you Contacted a lawyer? I would. I would be parking the car back at the garage and asking for my money back. Previously..
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16392 ![]() ![]() ![]() |
Stan, the fuel pumps always run (the same as if running on petrol) which is why so many problems arise from running an LPG car with very low petrol levels for a long distance... ![]() |
