![]() | Home > Maintenance & Mods (L322) > Wheel wobble at M/way speed with slight input to the wheel |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35771 ![]() ![]() |
no idea Ian sorry ....[just bumping this up for you |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700 ![]() ![]() |
Lower control arm. |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 ![]() ![]() |
Will this be the bush or the ball joint on the control arm? |
In my experience it will be the ball joint. The arm comes with both fitted anyway.
Should i buy OEM or does someone make them for LR? |
I used the britpart ones and they were a perfect fit. They looked 100% the same as the originals I took off.
wats39 Member Since: 08 Jul 2012 Location: fife Posts: 77 ![]() ![]() ![]() |
When i replaced mine i used britpart ones. i think they do make parts for land rover so you may end up paying a lot more for basically the same part but with a land rover logo on the box. T24RES, it might be worth swapping the front with the rear wheels to rule out the possibility of damaged tyres or wheel rims before buying anything. '04 td6 se
Thank-you for the tips. |
Which ball joint splitter will I need to purchase? |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
Something like this probably:
Found it thanks...............http://www.fullfatrr.com/forum/topic1632.html |
I have one like this for when I am feeling destructive!
my what a large fork andle you have |
four candles? ... - .- -.
