![]() | Home > Maintenance & Mods (L322) > Wheel wobble at M/way speed with slight input to the wheel |
| T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936
New lower arms are in. Will await the test drive. |
| Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700
Did you read about adjusting the large rubber bush on the arm?? If you fully tighten it when the car is jacked up it causes stress on the rubber when it goes back to normal position. When you assemble, leave the bolt slackish, then when the car is at normal ride height fully tighten it up.
I did thank-you. However getting a 3' torque wrench on the nut without it being on a ramp is not that easy.
Just returned from a w/end in Edinburgh. Lots of m'way miles and this appears to have cured my problem.
| Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2287
Good stuff replaced mine both sides the other month |
| All times are GMT |
