Home > Maintenance & Mods (L322) > Wheel wobble at M/way speed with slight input to the wheel
T24RES
As described, i've been experiencing this issue lately. Only noticable at higher speed and when either turning the wheel very slightly, just enough to load it or when braking at similar speed with slight turn. This exaggerates the wobble.
Straight ahead appears fine, as is heavy braking from same speed. Low speeds are all fine.
Now i'm assuming it is a control arm bush.
Mileage is @ 53K
Post #174340 24th Feb 2013 9:09pm
no idea Ian sorry ....[just bumping this up for you Wink ] ... - .- -.
Post #174498 25th Feb 2013 5:01pm
Lower control arm. Thumbs Up
Jack it up and there will be movement from top to bottom when you wiggle the wheel.. Previously..
Post #174499 25th Feb 2013 5:05pm
T24RES
Will this be the bush or the ball joint on the control arm?
Post #174536 25th Feb 2013 7:57pm
In my experience it will be the ball joint. The arm comes with both fitted anyway.
Here is an example...
http://www.ebay.co.uk/itm/RANGE-ROVER-L322...amp;_uhb=1 Previously..
Post #174539 25th Feb 2013 8:09pm
T24RES
Should i buy OEM or does someone make them for LR?
Post #174580 25th Feb 2013 10:23pm
I used the britpart ones and they were a perfect fit. They looked 100% the same as the originals I took off.
Personal choice tho' isn't it, Oem or not. I think britpart make parts for landrover do they not?? Previously..
Post #174584 25th Feb 2013 10:43pm
wats39
Scotland 2004 Range Rover SE Td6 Alaska White
When i replaced mine i used britpart ones. i think they do make parts for land rover so you may end up paying a lot more for basically the same part but with a land rover logo on the box. T24RES, it might be worth swapping the front with the rear wheels to rule out the possibility of damaged tyres or wheel rims before buying anything. '04 td6 se
'63 land rover s2 200tdi
'04 mk indy kitcar bike engine
Post #174592 25th Feb 2013 11:32pm
T24RES
Thank-you for the tips.
Post #174593 25th Feb 2013 11:36pm
T24RES
Which ball joint splitter will I need to purchase?
Post #175374 2nd Mar 2013 12:26pm
Something like this probably:
Sorry, a job I have not yet had to do. I think you may need one you hammer like a chisel, but there is a thread on here that shows how using jacks and big spanners. .
Post #175381 2nd Mar 2013 1:09pm
T24RES
Found it thanks...............http://www.fullfatrr.com/forum/topic1632.html
Post #175394 2nd Mar 2013 2:00pm
I have one like this for when I am feeling destructive!
Post #175420 2nd Mar 2013 5:16pm
T24RES
my what a large fork andle you have Laughing
Post #175436 2nd Mar 2013 7:49pm
four candles? ... - .- -.
Post #175437 2nd Mar 2013 7:51pm
