|  | Home > In Car Electronics (L322) > Bluetooth Install |
| comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1764      |
 Now I'm nearly ready to do this (hopefully this weekend) but have hit a snag already.
|  7th Mar 2013 12:05pm |
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8002      | Do a search for bluetooth antenna.
|  7th Mar 2013 7:12pm |
| comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1764      | Thanks Aaron
|  7th Mar 2013 10:00pm |
| comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1764      | Guys
|  8th Mar 2013 11:18am |
| ccfj1 Member Since: 14 Feb 2013 Location: UK Posts: 32    |
 BMW part 61-12-6-912-541 or http://www.ebay.co.uk/itm/GPS-1m-Antenna-E...1c2bcbef5c or http://www.ebay.co.uk/itm/Radio-antenna-Ex...45f4f5a019 or www.ebay.co.uk/itm/Fakra-A-Jack-to-Fakra-B...4603df29e6 Any of these will do, dont worry about the length, the BT antenna is good to 7-10m around the antenna, so you can have it in the boot. | ||
|  8th Mar 2013 12:52pm |
| Budgie Member Since: 09 Jul 2012 Location: Stornoway Posts: 267    | THIS is the genuine cable, although the ebay advert is from the U.S and not much help, but at least you can see what it looks like and maybe have a look around the BMW's in some local scrapyards to see if you can find one?   | ||
|  8th Mar 2013 2:22pm |
| comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1764      | Arghh. Can't try the pairing yet as the button is in the boot (with my new loom) and the procedure is to hold the button for a few seconds, then while holding it, switch on the ignition and continue to hold for a couple of seconds.... My Mrs won't help me as it's still raining...   | ||
|  8th Mar 2013 4:39pm |
| ccfj1 Member Since: 14 Feb 2013 Location: UK Posts: 32    | Use the intravee if you have one mate. | ||
|  8th Mar 2013 4:41pm |
| comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1764      | Good shout John - Let me try it that way instead.! but may wait till I dry off a bit first. Ash
|  8th Mar 2013 4:43pm |
| comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1764      | Well - thanks to ccfj I have now installed my bluetooth on the FF. Routed all wires back to the boot for the mic and all is good.......
|  15th Mar 2013 1:17pm |
 Make sure that the mic is in the correct way round mate, the arrow needs to point to the windscreen (I think).
 If its not that then try swapping the pins in the mic plug, could be RR are the opposite of BMW!! | ||
|  15th Mar 2013 1:39pm |
| comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1764      | Thanks John.
|  15th Mar 2013 1:43pm |
| ccfj1 Member Since: 14 Feb 2013 Location: UK Posts: 32    | You could try the mic loom plugged direct into the mic too, see what that does. | ||
|  15th Mar 2013 1:51pm |
| comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1764      | OK Have tried mic straight into bluetooth unit without the extra mic loom and also tried switching the pins on the lead and no change. Person in the car can hear very well but person being called hears nothing except very close up to the mic.
|  15th Mar 2013 2:23pm |
| Posting Rules
