Home > Technical (L322) > Smoke on very cold start up
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
I recently drove the Td6 down to the Alps for a ski trip and when I started her up in the cold and ice (-6 etc under a blanket of snow) she would kick out a fair bit of smoke and sound a little out of balance on tick over as though she was misfiring. Once warmed up there was no problem at all.
On returning to to the relative warmth of Blighty she starts up perfectly with no smoke, although there is sometimes an odd smell of burnt oil or fuel which goes after a minute or so.
Is this something to worry about or a sign of a key part about to go pop? Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #178827 21st Mar 2013 10:48am
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Sounds like you might have one or more glowplugs not er.. glowing!
They are the diesel analogue of the spark plug in a petrol (although completely different!) and like the spark plug they don't last forever.
Post #178831 21st Mar 2013 11:00am
NKSC
United Kingdom 2005 Range Rover Vogue SE Supercharged Zambezi Silver
The same thing happened to me a few years ago when I took my A6 Allroad to the Alps. On start up it would belch out a lot of black smoke. When it was warm it was fine and was ok cold starting when i had left the mountains. I put it down to the diesel waxing up in the continuous cold temperatures.
Post #178839 21st Mar 2013 11:37am
Flashman
I'll keep and eye on it, it starts up perfectly now the temperature is warmer. The smoke thing does happen occasionally in normal UK climate but is much less so, I guess it must be some fuel lingering about in the system at shut down. Tom
Current Drive
Previous Drives
Post #178841 21st Mar 2013 11:40am
The odd smell of burnt oil / fuel could just be exhaust fumes from the FBH ? .
Post #178846 21st Mar 2013 11:59am
Discotigger
More than likely caused by the fuel, I got a bit of smoke when I start up after a really cold night and I havent let the pre-heat and glow plug light go out. The diesel can wax up a bit, especially dependent on where you get your fuel (i.e. which garage chain you use). I use Morrison's for my fuel and notice that they put a percentage of 'bio-diesel' in their product, as opposed to Shell / BP who put additives in to 'enhance' their fuel.
More than likely nothing too much to worry about.
Post #179171 22nd Mar 2013 8:20pm
mercs600
England 2002 Range Rover Vogue Td6 Java Black
Used to get it on my TD5 Defender when the temperature drops below -10 degrees and still get the same with the Full Fat - I put it down to the diesel Wink Nothing to worry about Thumbs Up
Post #179244 23rd Mar 2013 4:26am
Flashman
Thanks for the answers guys, it looks like it must be a fuel thing as the temperature does seem to make a huge difference and once started there is no problem at all. Tom
Current Drive
Previous Drives
Post #179266 23rd Mar 2013 10:40am
