![]() | Home > Technical (L322) > Smoke on very cold start up |
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 ![]() ![]() ![]() |
Sounds like you might have one or more glowplugs not er.. glowing!
NKSC Member Since: 09 Nov 2011 Location: Lincs Posts: 156 ![]() ![]() ![]() |
The same thing happened to me a few years ago when I took my A6 Allroad to the Alps. On start up it would belch out a lot of black smoke. When it was warm it was fine and was ok cold starting when i had left the mountains. I put it down to the diesel waxing up in the continuous cold temperatures. |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1243 ![]() ![]() ![]() |
I'll keep and eye on it, it starts up perfectly now the temperature is warmer. The smoke thing does happen occasionally in normal UK climate but is much less so, I guess it must be some fuel lingering about in the system at shut down. Tom
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6428 ![]() ![]() |
The odd smell of burnt oil / fuel could just be exhaust fumes from the FBH ? .
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 ![]() ![]() ![]() |
More than likely caused by the fuel, I got a bit of smoke when I start up after a really cold night and I havent let the pre-heat and glow plug light go out. The diesel can wax up a bit, especially dependent on where you get your fuel (i.e. which garage chain you use). I use Morrison's for my fuel and notice that they put a percentage of 'bio-diesel' in their product, as opposed to Shell / BP who put additives in to 'enhance' their fuel.
mercs600 Member Since: 19 Mar 2011 Location: North Yorkshire Posts: 425 ![]() ![]() ![]() |
Used to get it on my TD5 Defender when the temperature drops below -10 degrees and still get the same with the Full Fat - I put it down to the diesel |
Thanks for the answers guys, it looks like it must be a fuel thing as the temperature does seem to make a huge difference and once started there is no problem at all. Tom
