![]() | Home > Technical (L322) > Trans Failsafe Prog - Another one!! |
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 ![]() ![]() ![]() |
Just a quick update............
Might be worth a look ;
Thanks - I did see that and then saw it is for a later car. |
Hi All,
Unless there is something really wrong, there is no physical way the transfer box can move you to Neutral or Low if there is no power going to the motor.
Hi Tim, Good to hear from you.
I can't plug the loom in as the TSM will put the transfer box back into Low Range and there it will stay! (The Hi / Low Switch is dead) I'm guessing this is because the transfer box ECU last remembers the vehicle being in Low Range and therefore wants to put it back there. What I need is to be able to plug the loom in to a "good" TSM, switch it back to High Range would probably resolve it. Why are those TSMs so ![]() 2019 Renault Zoe Dynamique Nav ![]() |
Sorry Steve, I forgot that was what it did when connected.
Also found this post with useful alternative info, worth a try?
Hi Tim,
So.........
It is possible to test the resistance of the wires from the ECU to the TSM.
Thanks Tim. Very useful.
Thanks Tim - Let's see how it goes. One day I may even have the bottle to try "Low" but for now I am just pleased to be able to use it properly again!
