![]() | Home > Technical (L322) > Calling RRPhil |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874
here,
| ebajema Member Since: 24 Mar 2011 Location: New Plymouth Posts: 4782
Bump. As in I tried Stan's suggestions but that didn't help MY 2010 5.0 SC Galway green and sand interior!!
he is about as he's posted here a couple of days ago.
Hi Stan, thanks, I noticed that so I am hoping that he sees this |
| RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1041
Hi ebajema,
Hi Phil,
Hi Phil,
Hi Phil,
| kingpleb Member Since: 07 Jun 2011 Location: Maybe here. Maybe there, I get everywhere! Posts: 8455
Eugene, Can BBS not supply the latest Firmware and then flash it even with the unit as it is? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
KP, yes they can, that is not the problem, the software is available for my model, I just need to download it. Before I sent the Faultmate back to them a few months ago, I had some issues with stability of the software on the Faultmate itself with regards to communication. When they sent it back (no faults found but reinstalled the firmware anyway) it seemed a lot more stable but I haven't used it much.
Ahh some risk |
Eugene, I wondered if the document you mentioned is the Sonnax one that I posted here : http://www.fullfatrr.com/forum/post155157.html#155157 or if you’d found a second source that states that the Delay Accumulator Piston might be responsible for your 3-4 shift problem? I haven’t yet stripped the valve block from my original 6HP26 teardown but I’ll remove this valve and report back on how easy/complicated the process is. I also have a second 6HP26 in my garage (actually from a Jaguar) which I haven’t yet started to disassemble so it may be that I can send you some different parts to try? Phil |
Hi Phil,
Eugene,
