Home > Technical (L322) > Brembos....
Page 3 of 3 <123
Googsy
Thumbs Up yes after watching video fronts look easy.look forward to seeing your write up for rears Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #170151 4th Feb 2013 11:35pm
http://www.fullfatrr.com/forum/post153377.html#153377 There is nothing that can't be fixed with a hammer😜😜
Post #170167 5th Feb 2013 8:34am
Googsy
Bow down Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #170194 5th Feb 2013 10:23am
Googsy
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #170195 5th Feb 2013 10:25am
Googsy
Did fronts today very easy thanks guys Thumbs Up rears look okay for the moment but will do these next week once I find my spanners Thumbs Up Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #172700 16th Feb 2013 4:13pm
Googsy
Quick question guys did the brakes as covered for the first time . I do have a squeak developing and believe its the rear brakes. I copper greased the rear pads on the back only hence the issue I have. Question is I can redo but where is the optimal point on the rear pads to grease around the botton where they sit into the retaining spring ?
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #179898 27th Mar 2013 11:19am
Stick copper grease on the whole of the rear of the pad like you are lavishly buttering fresh bread... Thumbs Up
How much of a wear lip do you have on your rear disks? As that can be a cause, also using cheap & nasty pads will squeak too... Thumbs Up
Post #179909 27th Mar 2013 12:32pm
Googsy
Disks look fine. Im using pagid pads. I literally only greased middle part of pad and not the anchor points at the rear which I suspect is causing the squeal.Am I right in thinking the anchor points slso need greasing at rear? Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #179991 27th Mar 2013 7:00pm
Yes they do sir Thumbs Up And the caliper where the pad fits in too... Thumbs Up
Post #180054 28th Mar 2013 12:06am
Mine are squealing now. Sounds like it may be the same thing on mine.
Tricky to tell where its coming from though. And its too cold to bother. There is nothing that can't be fixed with a hammer😜😜
Post #180144 28th Mar 2013 8:05pm
Pfazz
2019 Range Rover Autobiography SDV8 Loire Blue
Just a quick question to throw out there to people who obviously know what they are talking about, are all FFRR 's after a certain date fitted with Brembo brakes? I have a 61 plate SE but the brake calipers have a grey finish and are marked up as Range Rover and I wondered if they are in fact Brembos in disguise or if Brembos were an option. Agueroooooooooo. 93-20
I swear you will never see anything like this ever again....watch it..drink it in.
Post #180415 30th Mar 2013 11:04am
I think that the calipers on the post 2010 models 4.4tsv8 and 5.0sc are still brembos but just bigger and branded RR. they use completely different pads to the 3.6tdv8 and 4.2sc. There is nothing that can't be fixed with a hammer😜😜
Post #180462 30th Mar 2013 5:23pm
They are 6 piston or "6 pot" Brembo's on your car, just badged as Range Rover instead of Brembo by Land Rover... To answer your second question, they stopped fitting Brembo's on 09/10MY cars they started fitting them again in 2010... "maybe they ran out of factory stock Laughing "
Post #180539 31st Mar 2013 2:16am
Page 3 of 3 <123
