![]() | Home > General > Tow Bar Truth? |
SAppie Member Since: 08 Feb 2010 Location: Berkshire Posts: 159 ![]() ![]() |
Hi, and welcome.
stevegt Member Since: 17 Apr 2010 Location: Worcestershire Posts: 255 ![]() ![]() ![]() |
If you want to pm me with you VIN, i can have a look through your build specs on Microcat. That will tell me if your vehicle has a towbar prep fitted. Alternatively just look under your back bumper and look for the telltale square hole in the armarture under the bumper. This is it the centre of the vehicle.
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2947 ![]() ![]() ![]() |
Discussed here also:
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 798 ![]() ![]() ![]() |
FFRR towbar is an expensive option (>£1000). There's a lot more to it than the removable bit and if you are fitting it yourself then there is no need to go splicing into cables - all the additional loom just plugs-in. The older I get, the more I realise that people confuse wrinkles for wisdom |
DeltaC Member Since: 23 Mar 2010 Location: Aberdeenshire Posts: 148 ![]() ![]() ![]() |
Even though the wiring is straightward to install.. Its not quite plug and play and the car still needs to be "told" that it has the wiring by the Dealer or independent garage with appropriate computer.
Does it actually need to be programmed?? I've not seen any info for this in the Light Control Module programming? ![]() |
AFAIK, the programming required is purely for the rear PDC. When a trailer is attached (via the electrics) the rear PDC is automatically disabled to avoid the car constantly detecting the trailer. I'm not aware of any suspension programming and it is still possible to raise/lower the vehicle with a trailer attached.. |
When my trailer is hooked up, the suspension goes to standard setting, the little light comes on on the knob and it does not adjust height at speed.
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 ![]() ![]() ![]() |
Steve
Ian,
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6374 ![]() ![]() ![]() |
I've not noticed my PDC sensors switching off when I have a trailer.... Discovery 4 HSE
I haven't used a trailer with mine but I have used a towball mounted bike rack and when I connect the electrics the rear PDC is disabled. I think that this is mentioned in the owners handbook. I'm Not so sure about the suspension ride height though. This may be MY specific.
Rear PDC turned off and suspension locked in standard when caravan hooked up to mine.
I've not seen a gearbox mode in the WSM, I have however noticed the shift pattern seems to change when towing but it is more akin to "Hill Mode" that just detects that it needs to hold onto the gears for longer. I would have though hill mode would be the equiv of a towing mode. On the newer terrain response models I believe there is a towing mode (Trailer Stability Assist) for the DSC that counteracts trailer sway: Can't say I'd like to test that sway test out! ![]() |
