![]() | Home > Technical (L322) > Calling RRPhil |
If needed Eugene I can do the usual as the bumper hasn't gone yet so I can hold off if you want more bits with it |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1033 ![]() ![]() |
Yes, of course....but I know even less about the 5L40-E ![]() Phil |
I just need a minute of live data of the engine running from another msv2 owner for the injector and fuel systems sections so I can compare the numbers with mine which I think is a HP pump issue |
Actually ignore me, I thought you had a td6 for some reason! Total blonde moment |
There are a three significant things going on with the transmission control system when a 3-4 upshift is triggered (i.e. B-clutch is disengaged while E-clutch is engaged) :
Hi Phil, I can only find the Capture Data function for the Petrol EMS which has no data about the transmission. The transmission doesn't show any data capture option like that. I am running 1.31a of the VE.
Phil, I was doing some more Google research on the gearbox issue and found one of your posts on Rangerovers.net. In that post you recommend reflashing with one of two software upgrades. How do I know which one is best for my car. Note: I use the versions that Blackbox Solutions have on their website, supposedly they get them directly from JLR.
And the plot thickens. Tonight I did my little run to move the oil through the box before I have the oil changed again on Saturday. The first run (cars warm up very fast here) was OK-ish flaring but not the full monty bang. So the next round was in manual.
Tonights little drive showed that if you keep a decent bit of acceleration going, the 3-4 shift issue is not there. Mind you, on the roads here and with a SC that is not an option but still it shows that it can still do a good 3-4 shift.
What kind of laptop are you trying to use?
I'm using a Toughbook CF-M34 that came with XP prof and SP2. For the flash file loader you need .Net Framework 3.0 minimum.
.net framework downloaded but still doesn't work, now I do get a fault report on the Flash File Loader. Will have another go tomorrow. MY 2010 5.0 SC Galway green and sand interior!!
Completely re-installed XP with SP3 and .NET Framework and it is working fine now. Transferred the two VBF files to the Faultmate and hopefully I get my chance this weekend to flash the ECU. MY 2010 5.0 SC Galway green and sand interior!!
The reflash is done, took less than 20 minutes (although three but that is due to Faultmate software not working perfectly). Anyway, it did not do anything for the 3-4 shift so I am using the car in tiptronic mode (and it does well in that mode).
