Home > In Car Electronics (L322) > Pre-touch-screen options for Line In....
jerrytlr
France 2003 Range Rover Vogue 4.4 V8 Oslo Blue
Hi all, I am about to take the plunge and buy an L322 to replace my trusty old P38. Time will tell if this is a good idea!! The car I am looking at is a 2003 vogue non-touch-screen sat nav.
In the P38 I have an aftermarket Parrrot Asteroid head unit which gives me ipod, aux in, bluetooth phone and audio - ie pretty much everything you want. It took 15 mins to fit Smile
So, I have been researching on here to find out how to get similar functionality in the L322. Oh dear.... confused!
So, apologies for starting a new thread on what is already a fairly well discussed subject, but having searched and read loads I am struggling to summarise my options.
All I really want to do is have an aux in that I can connect to my Android phone, which I use for stored music and also streaming over 3G (Deezer). The phone is a Galaxy note II so it is big enough, and has a good enough screen, to use whilst on the move, as long as I put a mount for it somewhere sensible.
So question 1 - does the 2003 vogue have an aux in? If not, can it easily be added and, if so, how?
Assuming the answer to the above is no or too expensive, then having the ability to stream bluetooth audio would be just as good, better in some respects.
So question 2 - if the car has bluetooth already fitted as an option, does this have audio streaming or is it only for hands free telephone?
and question 3 - does the bluetooth upgrade support more modern phones?
If the bluetooth upgrade will not support audio, and the aux in option is a no-go, then I guess I will have to go the iPod route.
So question 4 - to add iPod, am I right in thinking that the intravee is the way to go? I saw some sad news that the developer had passed away, is the intravee still available?
And finally - there are several threads which seem to conclude that ripping the whole lot out and replacing with aftermarket is the way to go. It seems a real shame to ditch the HK audio setup - so,
Last question - can you connect a different head unit to the HK processor/amp?? Alternatively, can a Parrot be made to work with the HK?
Sorry for all the questions, hopefully somebody can help!
Best regards
Jerry
Post #180996 3rd Apr 2013 8:17am
SFM
France 2012 Range Rover Vogue TDV8 Rimini Red
Hi
Not to sure about aux in etc, but pretty sure that this is the same system as fitted to my BMW M3, I went for a Dension ice link, just connect to the Ariel input. Volume control from steering wheel, and charges phone/ I pod. About £100
Post #181007 3rd Apr 2013 9:27am
Intravee was great in my old touch screen Thumbs Up
You could have a Parrot bluetooth kit installed too but not to stream music as the "low input" wiring for the handsfree speakers are only on the fronts... Big Cry
Post #181025 3rd Apr 2013 10:33am
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Simplest way is to install a Parrot MKi9200 - it's what I use and have the phone (Samsung S3) on a Brodit mount - all nice and tidy.
Post #181030 3rd Apr 2013 11:48am
jerrytlr
Thanks Simes - how does the Parrot connect to the HK system? I am pretty familiar with their products but the Parrot setup I have in my Subaru intercepts on the speaker wires so bypasses all of the built in audio stuff. Not sure how you could intercept the speaker wires with the HK...
TIA
Cheers
Jerry
Post #181045 3rd Apr 2013 1:40pm
Simes
Mine was fitted with a proper set of leads that connected it into the amplifiers, not the speakers, so that when listening to music you still get the fm traffic flashes and voice of the sat navigation lady!
The chap I use fitted the lot in about an hour.
Post #181048 3rd Apr 2013 1:46pm
jerrytlr
That does sound like a very good solution then - what is the OEM setup in your car? Pre touch screen satnav and HK?? What year is it?
When you play music, does the audio from the phone come out of all the speakers?
Sorry for all the questions!
Cheers
Jerry
Post #181049 3rd Apr 2013 1:50pm
Simes
Mine is the 2004 vogue with HK audio and DSP. Music comes out of all the speakers from the phone by either bluebook or direct from the USB connector. Telephone calls come out of the front speakers only. Mine is pre-touch screen.
Post #181065 3rd Apr 2013 2:34pm
The other ways are
1. To have your BM54 radio unit upgraded by Baris (on forum) to provide an Aux In
2. To use the audio inputs (mono) for the TV
3. Try the audio inputs for the Tape Unit
All three will require you to run a cable from back to front.
Lots of info on thread here (ignore CarPC stuff if that is not your thing Wink :
http://www.fullfatrr.com/forum/topic8786.html .
Post #181108 3rd Apr 2013 8:12pm
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
If I'm not mistaken the aforementioned Baris can also do a mod to enable streaming via bluetooth..! Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #181133 3rd Apr 2013 10:10pm
RR2008HSE
Not the most elegant solution, but the 03 has a cassette player, so you can get one of those AUX IN cassettes. It's easy, cheap and you don't have to modify the car. Also, it's a stop gap measure while you explore other more elegant or permanent solutions.
Post #181150 4th Apr 2013 7:20am
Bushy513
United Kingdom 2003 Range Rover Vogue Td6 Monte Carlo Blue
I am using the cassette aux method as described above, cheap and cheerful. It's only a temp until I have time to fit an intravee. Really I would like to replace the entire head unit for something a bit more modern, but I am yet to find a solution for the vogue with DSP. Bushy
2003 RR Vogue Monté Carlo Blue
Post #182489 11th Apr 2013 11:03pm
jerrytlr
Hi all thanks for all the very helpful replies
I picked up the car a couple of days ago and am very pleased with it - however not being able to play music from my phone is a problem that needs to be sorted asap - can't be messing about with CDs gave that up ages ago!! Smile
I am very pleased with the sound quality of the OEM stuff and the general look and feel of it, so want to upgrade rather than replace.
My preference is to use bluetooth streaming - getting Baris to mod the unit seems the way forwards for this but I have not always had brilliant experiences with bluetooth audio in the past - can be hit and miss especially older bluetooth with newer phones - so I was wondering if anybody has first hand eperience of this mod and can give me some feedback?
I also plan to update to DVD Sat Nav. Those two mods will get the ICE stuff up to where it needs to be for me Smile
Best regards
Jerry
Post #182590 12th Apr 2013 8:11pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
Hey ... at least you guys had a cassette .. my first L322 had a &^&*%^$%$ mini disc!!?! Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #182601 12th Apr 2013 9:01pm
Bushy513
Rolling with laughter Rolling with laughter Laughing Bushy
Post #182621 12th Apr 2013 9:45pm
