![]() | Home > In Car Electronics (L322) > Pre-touch-screen options for Line In.... |
| SFM Member Since: 19 Feb 2012 Location: dordogne Posts: 263
Hi
Intravee was great in my old touch screen |
| Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964
Simplest way is to install a Parrot MKi9200 - it's what I use and have the phone (Samsung S3) on a Brodit mount - all nice and tidy. |
| jerrytlr Member Since: 02 Apr 2013 Location: France Posts: 66
Thanks Simes - how does the Parrot connect to the HK system? I am pretty familiar with their products but the Parrot setup I have in my Subaru intercepts on the speaker wires so bypasses all of the built in audio stuff. Not sure how you could intercept the speaker wires with the HK...
Mine was fitted with a proper set of leads that connected it into the amplifiers, not the speakers, so that when listening to music you still get the fm traffic flashes and voice of the sat navigation lady!
That does sound like a very good solution then - what is the OEM setup in your car? Pre touch screen satnav and HK?? What year is it?
Mine is the 2004 vogue with HK audio and DSP. Music comes out of all the speakers from the phone by either bluebook or direct from the USB connector. Telephone calls come out of the front speakers only. Mine is pre-touch screen. |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
The other ways are
| comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1764
If I'm not mistaken the aforementioned Baris can also do a mod to enable streaming via bluetooth..! Ash
| RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932
Not the most elegant solution, but the 03 has a cassette player, so you can get one of those AUX IN cassettes. It's easy, cheap and you don't have to modify the car. Also, it's a stop gap measure while you explore other more elegant or permanent solutions. |
| Bushy513 Member Since: 25 Feb 2013 Location: Colchester Posts: 392
I am using the cassette aux method as described above, cheap and cheerful. It's only a temp until I have time to fit an intravee. Really I would like to replace the entire head unit for something a bit more modern, but I am yet to find a solution for the vogue with DSP. Bushy
Hi all thanks for all the very helpful replies
| DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027
Hey ... at least you guys had a cassette .. my first L322 had a &^&*%^$%$ mini disc!!?! Land Rover Addict
| All times are GMT |
