![]() | Home > In Car Electronics (L322) > TV tuner lost its channels! |
MarkBrand Member Since: 05 Feb 2012 Location: Belfast Posts: 39 ![]() ![]() ![]() |
I am stuck on this one! I have a TV tuner that can't pick up any channels, both antenna plugs are installed and the fan is going round in the tuner box so there power, another problem is that you can't can't change country or format options, I don't know...might be related! I bought the tuner in oct and its hasn't worked since before crimbo! Any ideas would be appreciated as I can't get hold of the guy that sold me it! |
Yea it's a hybrid dig. Tuner! It did work for a few days! |
NormanP Member Since: 15 Mar 2013 Location: Oxford Posts: 136 ![]() ![]() ![]() |
http://www.digitaluk.co.uk/when_do_i_switch
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35765 ![]() ![]() |
have you checked the connections?
Yes I have checked them a few times, all seams well, the analogue tuner went on eBay! |
Baris Member Since: 06 Mar 2012 Location: North London Posts: 95 ![]() |
Sounds about right. These £400 -£500 tuners are failing more and more. That's why its better to a digital conversion done on the analogue tuner. |
But you can't do that with the MOST system ones baris |
I take it this has happened to more than one, can it be fixed? I sent you an unrelated pm Blaris. |
It's very confusing on this forum, as both generations of range rovers are in the same sections. I'm assuming the MOST system your referring to is the entertainment system in the touch screen system? Which I don't know much about tbh.
Yes, it's a touchscreen version, any luck on the Bluetooth issue mentioned in my pm or is that not your department? |
martin g Member Since: 10 Mar 2013 Location: Somerset Posts: 14 ![]() ![]() |
had this with my tdv8 try pressing auto then your stations should retune |
Are there any forum members that offer a fixing service? It won't find any channels and it won't let me change country or format options, have checked all connections and ariels and all is well in that department. I only got to watch tv once since I bought it which is annoying. |
Just bumping this up again, as I need to get it fixed or replace it, Had no response from the guy I bought it off! Lesson learnt! 👎 |
does increasingly sound like a dodgy tuner...you might have to bite the bullet and get another one if you cant find a repairer. ... - .- -.
