![]() | Home > Technical (L322) > Tyre Pressure Monitoring |
504cash Member Since: 31 Mar 2010 Location: Reading Posts: 11 ![]() ![]() ![]() |
Does anybody know how to turn the system off completley ? |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2074 ![]() ![]() ![]() |
I was told, by my dealer, it could not be done.
Many thanks, Ill ask the dealer again but they tell me it is not an option on IDS Diagnostics.
504
jayzee Member Since: 14 Oct 2009 Location: UK Posts: 342 ![]() ![]() |
Mine's deactivated; I have no idea how it was done though as it was the PO that I assume sorted this.
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6382 ![]() ![]() |
I think it would still throw a fault.
RRV Member Since: 05 Oct 2009 Location: Midlands Posts: 648 ![]() ![]() ![]() |
Mine is the same......every few minutes the sign pops up then the message.It spoils my enjoyment of the car tbh. ![]() |
The TPMS has to be installed and tested in the vehicle manufacturing environment. The process is generally as follows. The TPMS sensors are attached to the wheel during the wheel and tyre assembly process. The wheels are then attached to the vehicle. This is the first point at which the TPMS can be clearly associated with the vehicle. In the case of battery-powered RF systems, it is on this final car assembly line that RF antennas are used to extract the unique IDs of the TPMS. These IDs, and their associated wheel position on the car are downloaded to the vehicle Engine Management Unit. This enables warnings to be associated with wheel position.
Nothing to do again Mick |
Joys of retirement Nigel .......... |
