![]() | Home > Maintenance & Mods (L322) > Boot lettering measurements. |
There has been a few posting recently regarding Range Rover Lettering. I recently changed my lettering with cheaper non genuine lettering and as a result I did not position the boot lettering correctly. I now have some genuine lettering i would like to replace it with .Could someone to please advise the following measurements I'm sure this will help other members in the future too.
Bantam Member Since: 20 Feb 2012 Location: Cheshire Posts: 27 ![]() ![]() |
Hi There,
Well on mine …… This is the Rear Letters
Interesting would be good to get 3rd measurements to confirm cheers Mick |
On mine
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3945 ![]() ![]() ![]() |
There's a lot of good info on here regarding spacing etc but the lettering does extend past the boot strip and so i measured 43mm to the bottom of the first and last "R's" with my flexitape hooked under the bottom edge of the upper tailgate. I would suggest a straight line (drawn with a white board marker or something else that rubs off easily) between the two points will give you a decent base line.
For the bonnet - it's easier just to find the centre of the grill and then mark the centre of the bonnet accordingly and the lettering is 45mm each side of that line - 90mm apart as stated elsewhere. Geoff |
