![]() | Home > Technical (L322) > dont need dealer to program new key. |
hi,i have done it, i have managed to clone lost keys or add new keys to the range rover with the bmw ignition system, but i think i went over the top and now have 6 keys for the car |
barracuda816 Member Since: 11 Jun 2012 Location: oxfordshire Posts: 213 ![]() ![]() ![]() |
is it just me or have you replied to your own thread? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35762 ![]() ![]() |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1762 ![]() ![]() ![]() |
Dave's trying to convince himself that having 6 keys is a must...
i got a bit carried away with my self, the stealers wanted 250+ after programming and i was ot going to pay that. so the thought of only having one key and if it got lost is not something i wanted to think about.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
So what do we need to do this daveo ? Is it cheaper than buying a key from the stealer ? What if I only have one key? .
you need a unit called EWS Editor, new chip, and a key blank, the hardest part is removing the EWS unit from the car(center consle out) as you need to read this with the new tool, this is the bit where you can do the damage, you need to touch a pin on the board to read, after you get the info from the unit you can start writing a new key,once done then its back to the EWS and you have to write back to it and tell it that a new key is on the system.
Rich86 Member Since: 10 Mar 2013 Location: Surrey Posts: 509 ![]() ![]() ![]() |
Like many owners I suspect I'd like to freshen up one of my keys which has a pierced case through wear and tear but this doesn't seem like a job for the faint hearted. |
not a very hard job at all, what type of key do you have rich V8 facelift Range Rover Autobiography 22" wheels.
It has arrow to open, large button to close and boot release with red light in the corner. Probably original I would say dave. |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 ![]() ![]() ![]() |
hi daveo i like the sound of this little project |
Daveo I've replied to your question... |
rich, you can recase your key for around 10 pounds
matt, your key that is locked out can be re coded, i think i have one transponder chip left, i can do youa key FOC but you would need to send me you ews unit V8 facelift Range Rover Autobiography 22" wheels.
