Home > Maintenance & Mods (L322) > Park heater problem.
DeRanged Rover
United Kingdom 2006 Range Rover Vogue SE Td6 Java Black
Hey all,
New gremlin has surfaced. Just got home and one and off whooshing sound from front left engine bay - sounds like the FBH heater coming on and off - hasn't even stopped after turning the car off - at this rate battery will be dead pretty soon.
Plugged in the iid tool and got the following errors
1) park heater message disturbance fault
2) air quality sensor line fault
3) combustion air fan - open circuit or short circuit to battery.
Any thoughts???
Many thanks guys! African Bush Junkie ... in London!
Stats:
2006 TD6 Vogue SE
1972-2015 DeRanged Rover
2001 P38 dHSE (SOLD)
Post #181883 8th Apr 2013 7:59pm
Monty1
England 2005 Range Rover Supercharged 4.2 SC V8 Rimini Red
can the fuse be pulled maybe,
Post #181897 8th Apr 2013 8:57pm
DeRanged Rover
Good idea. I'll try that as a temp fix. African Bush Junkie ... in London!
Stats:
2006 TD6 Vogue SE
Post #181902 8th Apr 2013 9:00pm
Let me know which one mine is doing the same Thumbs Up
Post #181905 8th Apr 2013 9:05pm
DeRanged Rover
Fuse 59 isn't it? African Bush Junkie ... in London!
Stats:
2006 TD6 Vogue SE
Post #181926 8th Apr 2013 10:25pm
fuse 59 Thumbs Up ... - .- -.
Post #181951 9th Apr 2013 8:53am
DeRanged Rover
Any thoughts on what this could be?
Is the outside temperature at that odd level where the sensor is confused as to whether or not it should activate the FBH?
Although it seems strange that this was happening after the car was switched off. Am going to get the battery voltage checked too just in case.
C African Bush Junkie ... in London!
Stats:
2006 TD6 Vogue SE
Post #181993 9th Apr 2013 1:20pm
taskam
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
Was the engine fully warmed up? My FBH will keep running for a while if I've had the engine running for only a few minutes. 2007 TDV8 Vogue SE Java Black
Post #181996 9th Apr 2013 1:31pm
1. park heater message disturbance fault..... glowplug? http://www.fullfatrr.com/forum/topic8274.html
2. air quality sensor line fault.... http://www.fullfatrr.com/forum/topic9846.html?view=next
3. combustion air fan - open circuit or short circuit to battery... glowplug? http://www.techwebasto.com/academy_data/PC...Tables.pdf ... - .- -.
Post #181997 9th Apr 2013 1:32pm
DeRanged Rover
Thanks Stan! African Bush Junkie ... in London!
Stats:
2006 TD6 Vogue SE
Post #182120 10th Apr 2013 12:35am
