Home > Technical (L322) > Battery Dies
cliffy
2004 Range Rover Vogue 4.4 V8 Zambezi Silver
Battery Dies
My battery keeps loosing its charge, I only use the RR every now and then
It takes between 1-2 weeks then its flat
I'm think FSR does this sound about right?
Thanks
Neil[/url]
Post #182310 10th Apr 2013 11:12pm
Rich86
United Kingdom 2009 Range Rover Vogue TDV8 Nara Bronze
If you don't use it that often then it will lose its charge.
Buy a trickle charger and keep it on this if you can.
Post #182317 11th Apr 2013 6:25am
roger 47
United Kingdom 2017 Range Rover Autobiography SDV8 Fuji White
I left mine for a couple of week in the snow, started with no problem.
I would say your battery is on it's way out.
A trickle charger would help but your only delaying the inevitable. '88 RR Classic, '90 Classic, '93 Classic, '02 Discovery TD5, '55 Discovery 3, '01 P38 4.6, '06 L322 Vogue TD6, 2012 L322 Vogue TDV8, 2017 L405 Autobiography
Wife. '01 Freelander, '07 Freelander 2.
Post #182322 11th Apr 2013 8:04am
Neil, how old is the battery ? what voltage is the alternator pushing out ? ... - .- -.
Post #182338 11th Apr 2013 8:58am
cliffy
The battery isnt a year old, ive had concern re the alternator but ive had no other issues just leaving it for 2 weeks and it dies, this is even after motorway runs etc
Maybe ive got a current draw on it like the satnav unit etc
Post #182376 11th Apr 2013 11:54am
cliffy
Have I been fobbed off the ampage of the battery is at 700 amps and its over a 900 amp battery
Is any amount of charging going to improve this or is it a new battery??
Post #182420 11th Apr 2013 4:59pm
are you saying yours is a 700amphr battery? if so then its to small.. ... - .- -.
Post #182423 11th Apr 2013 5:01pm
cliffy
No it's a bosch 900 something silver battery thing
Post #182427 11th Apr 2013 5:53pm
Instead of guessing what the problem is it would be worth disconnecting the battery -ve terminal and connecting an ammeter with a 10A range between the battery -ve terminal and the earth jump stud on top of the suspension mount, closing the car doors and leaving it for 30minutes.
Then go back and see what the current reading, if any, is.
Leaving the bonnet open while you do this won't affect anything. Thumbs Up
Post #182429 11th Apr 2013 6:25pm
