![]() | Home > Technical (L322) > RSW Allcoms won't clear Airbag light FIXED |
good news and when you get to fix it yourself adds to the satisfaction |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35737 ![]() ![]() |
result.. |
Rich86 Member Since: 10 Mar 2013 Location: Surrey Posts: 509 ![]() ![]() ![]() |
Well done mate. Phew! |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2947 ![]() ![]() ![]() |
It was a pig of a job to do, mainly because of having to get the centre console out. A tip if anyone ever has to do it- just take the screws out and lift the rear of the console up and slide a broom stale across the seats to hold it up out of the way. The ecu is under the heater blower which is fixed to a metal frame. That frame then needs to be unbolted to access the ecu. No need to take the front clock panel out as RAVE suggests |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
had this on a 2002 i bought, RSW lead would show but not clear fault. bought a secondhand battery disconnect cable as that was the offending text fault along with 'internal error'. still on!
Annoyingly, when I returned to retest the car, the tester informed me that a loophole had been discovered in the new legislation.
