![]() | Home > Technical (L322) > Rear light question |
| RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6383
Ive lost count of the numbers of rear lights my dad has smashed on his 2004 car, keeps reversing into walls and posts on the shoot.
| JOKER Member Since: 11 Sep 2008 Location: Sconnie Botland Posts: 15876
Mine are the same with no wiring in the loom part either , only ones I have seen lit are in the States not seen one in the UK , was thinking a while back of getting them wired up tho |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35877
the american market specified having 'side' lights on the side...hence the new l405 front/rear lights bending around the sides.. ... - .- -.
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
Is there a bulb/bulb holder there too ? Does it work with power supplied ?
Tut tut Adam , a Mod posting in the wrong section and getting it moved |
Mick, yours should have (09MY>) LED rear lights already... If yours are NAS spec you won't see any wiring for the side markers as they are LED's too and in the 09my> the LED's and wiring is all hidden... Craig |
Problem is with yours Mick, you can only do the rears as you cannot purchase RHD NAS headlamps |
| wats39 Member Since: 08 Jul 2012 Location: fife Posts: 77
The front headlights 06-09 do have the fitting for the side markers already there. the sidelight bulb holder fits it so if you managed to source a couple of these then you would just have to wire them in. was thinking of putting led's in the existing sidelights of mine to match the xenon headlights and the normal bulbs in the side markers so as not to bring up any faults or overload anything. any wiring would be inside the headlight unit then. '04 td6 se
| RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932
If he's always backing into posts, I'd check the parking sensors and the rear view camera before worrying about NAS vs Euro lighting differences. |
Sunday morning laziness Mick. Guilty as charged! Discovery 4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 Hard Top 1998 90 TUL FFR Hard Top XD Wolf 1993 90 Tdi *Gone: L405 4.4 VSE, L462 D5 HSE LUX, L663 Defender 110 HSE, Discovery 3 HSE, 2014MY Range Rover Sport 5.0 Supercharged AB Dynamic; L405 Exec Vogue SE 4.4, 5.0 Supercharged Autobiography, Defender TDCi XS CSW, Defender TD5 HT, Vogue SE TDV8, Vogue TD6, RRSport SC 4.2V8, Classic 3.9 Vogue Auto, Land Rover Series 3 SWB |
| Bushy513 Member Since: 25 Feb 2013 Location: Colchester Posts: 392
what is the rear reflector post called in the wiki? Bushy 2003 RR Vogue Monté Carlo Blue |
| All times are GMT |
