![]() | Home > Maintenance & Mods (L322) > Adaptive headlights failed to adapt |
| RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597
Hi Folks, had an issue the past 4-5 days with my offside headlight failing to adapt when turned on, it basically sat pointing downwards and failed to do its auto-align. Had this a while ago and turning the car off/on a few times cured it but this time it didn't. Anyway , removed headlamp unit to check the worm screws etc and seemed Ok, I manually wound the left /right align worm screw backward and forward, but the vertical adjust was very hard to access and appeared to be driven by a Hella motor , which to remove I would have to dis-assemble the light unit as could not access 1 of the 2 screws. Decided to put unit back in the car and do a hard reset but on turning the engine over once refitted, it kicked back into life so all OK again. The knock on from this is that I noted down the part number for the Hella motor - it is marked in the below format..
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35879
thanks for heads up Steve.. |
Thanks guys. Dave, think you meant left not right by the way for the location of the horizontal alignment motor as it's top left of the picture posted. Do you guys know if you can buy the lens retaining clips seperately or do they only come with the headlight unit? It's just I noticed the middle top one of my nearside unit is missing (funnily, the OSF unit middle one was pretty loose so I 'tightened' it up a bit) and eventhough it will make little difference, I want to replace it.
for any bits required Steve, its best to ask in dan @ duckworths section or try ebay.. ... - .- -.
Will do, Thanks Stan Steve
| All times are GMT |
