![]() | Home > Technical (L322) > Drivers door key |
Bushy513 Member Since: 25 Feb 2013 Location: Colchester Posts: 392 ![]() ![]() ![]() |
Just tried to get into my car, and for once thought I'd try the manual key instead of remote open/close on the fob. Wish I hadn't now as now I know it doesn't work |
How would that help? Bushy
Budgie Member Since: 09 Jul 2012 Location: Stornoway Posts: 267 ![]() ![]() |
If the battery goes flat and it won't open the central locking you can plug another battery/car into the rear socket and to give enough power for the central locking to work. |
Wow |
@ niceday
No need to take the door card off, just remove the outer handle and lock and reset the cam to the central position |
Ok I'll give that a try. Bushy
Just reading up on how to do that, and you still need to take the door card off |
I think it's the second socket for trailers that's the one which can be powered. This has two pins for battery charging or power and an earth. http://www.watling-towbars.co.uk/wiring_gu...wbars.html ![]() ![]() |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3982 ![]() ![]() ![]() |
@Joe90
No you don't, open the door and look at the back, there is a grommet, remove this and it gives access to a torx bolt, remove that and the handle comes off. The lock assembly then lifts out and you have to realign the part that's left inside the door. Just use a screwdriver to do this and reassemble. |
Can you also change out the door handles like that ??? MY 2010 5.0 SC Galway green and sand interior!!
Ok thanks for your help, I will have a look today. Bushy 2003 RR Vogue Monté Carlo Blue |
