Home > Technical (L322) > Drivers door key
Bushy513
United Kingdom 2003 Range Rover Vogue Td6 Monte Carlo Blue
Drivers door key
Just tried to get into my car, and for once thought I'd try the manual key instead of remote open/close on the fob. Wish I hadn't now as now I know it doesn't work Censored
Is this common?
I'm not too bothered by it, other than reading about all the battery faults with the vehicle, that could potentially leave me stuck outside of it. Big Cry Bushy
2003 RR Vogue Monté Carlo Blue
Post #183899 21st Apr 2013 2:33pm
The key not un-locking is only common if there is a fault. Laughing
Time to get the door card off and have a look.
Probably a link problem.
You really do not want the door to be un-lockable by the key.
Do you have tow bar electrics just in case the inevitable happens?
Post #183902 21st Apr 2013 2:42pm
Bushy513
Laughing I can understand that.
Yes I have a 13 pin socket at the rear. Bushy
Post #183904 21st Apr 2013 2:55pm
Bushy513
How would that help? Bushy
Post #183909 21st Apr 2013 4:37pm
Budgie
If the battery goes flat and it won't open the central locking you can plug another battery/car into the rear socket and to give enough power for the central locking to work. Wink
Post #183910 21st Apr 2013 4:46pm
Bushy513
Wow Shocked that's good. Bushy
Post #183912 21st Apr 2013 4:47pm
@ niceday
Can see I can buy a trailer socket plug, wiring indicates a "ground" (earth?) but all the other connectors only seem to be for lighting circuits. How to wire up for a battery / charger ?
for example:
Post #184145 22nd Apr 2013 11:57pm
No need to take the door card off, just remove the outer handle and lock and reset the cam to the central position
Post #184147 23rd Apr 2013 12:05am
Bushy513
Ok I'll give that a try. Bushy
Post #184151 23rd Apr 2013 12:41am
Bushy513
Just reading up on how to do that, and you still need to take the door card off Laughing Bushy
Post #184153 23rd Apr 2013 12:45am
Budgie
Joe90 wrote:
@ niceday
for example:
I think it's the second socket for trailers that's the one which can be powered.
This has two pins for battery charging or power and an earth.
http://www.watling-towbars.co.uk/wiring_gu...wbars.html Wink
Post #184154 23rd Apr 2013 12:45am
@Joe90
It's the supplementary plug you need. The white one.
+12V to pin 4, earth to pin 3.
If you have a Cteck charger much easier to buy the adaptor from the site shop. Thumbs Up
Post #184166 23rd Apr 2013 7:31am
No you don't, open the door and look at the back, there is a grommet, remove this and it gives access to a torx bolt, remove that and the handle comes off. The lock assembly then lifts out and you have to realign the part that's left inside the door. Just use a screwdriver to do this and reassemble.
Post #184169 23rd Apr 2013 7:59am
ebajema
Can you also change out the door handles like that ??? MY 2010 5.0 SC Galway green and sand interior!!
Post #184185 23rd Apr 2013 9:37am
Bushy513
Ok thanks for your help, I will have a look today. Bushy
Post #184192 23rd Apr 2013 10:16am
