Home > Technical (L322) > sun roof operation
SoggyBottoms
United Kingdom 2007 Range Rover Vogue Supercharged Zambezi Silver
sun roof operation
I nearly gave myself a heart attack earlier.
went out to the car and as it was hot I opened a coupla windows and the sunroof
then I started the engine, closed the windows and set off.
when I set off I pressed the door lock button on the centre console as I always do
thinking it was a bit windy going along I pressed my sunroof button to close and the fecking thing didn't do anything.
I was thinking "blimey, hope it's a fuse"
wasn't until I tried it after turning off the door lock button that it operated.
so, how on earth can that make sense?
why wire the sunroof into the door locks?
or is my car different to others?
Post #183952 21st Apr 2013 8:12pm
CG-SC
2006 Range Rover Autobiography Supercharged Zambezi Silver
I've had this several times - if I switch the igntion off and then back on the roof workls again - happened about 3 times now - no idea why !! Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #183953 21st Apr 2013 8:16pm
E4 GUY
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Same here . Closed by holding remote button Wink Alcohol and eBay is never a good mix
2006 4.2 Supercharged, Java Black
Post #183959 21st Apr 2013 8:59pm
Bushy513
United Kingdom 2003 Range Rover Vogue Td6 Monte Carlo Blue
Why did you press the lock button? It should auto lock over a certain speed, although I guess this can be deactivated.
I'm guessing that once you press the button the car acts as if you've locked it from outside and prevents sunroof movement. But it doesn't really make sense to me either. Bushy
2003 RR Vogue Monté Carlo Blue
Post #183960 21st Apr 2013 9:02pm
SKOT
England 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
My understanding is that on a UK car, this defaults to inactive.
My FF has autolock enabled because I went in via T4 to activate this feature to the US Spec. I guess someone has manually activated yours at some time in the past too....
@Soggy - Get autolock turned on if you like this feature. It's one less thing to remember after takeoff! 2006 4.2 SC
2019 Renault Zoe Dynamique Nav
Post #183974 21st Apr 2013 11:27pm
Bushy513
Ah I see, oh well. I just tried pressing my button and activating the sunroof and it kept resetting to where I stopped it, weird!
However with the auto lock it works perfectly. Rolling Eyes
I agree get the auto lock turned on its a lot easier and apparently different. Bushy
Post #183982 22nd Apr 2013 1:11am
davidmg
2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
My sunroof would open but not close unless you switched the ignition off and on again, then it worked again. I cured it by resetting the sunroof. I have now enabled auto lock and there is no problem with the sunroof operation, therefore try resetting the sunroof to see if that fixes it
Post #184430 24th Apr 2013 12:00pm
