![]() | Home > Technical (L322) > sun roof operation |
SoggyBottoms Member Since: 05 May 2012 Location: Northants. Posts: 457 ![]() ![]() ![]() |
I nearly gave myself a heart attack earlier.
E4 GUY Member Since: 07 Jan 2013 Location: London Posts: 513 ![]() ![]() ![]() |
Same here . Closed by holding remote button |
Bushy513 Member Since: 25 Feb 2013 Location: Colchester Posts: 392 ![]() ![]() ![]() |
Why did you press the lock button? It should auto lock over a certain speed, although I guess this can be deactivated.
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 ![]() ![]() ![]() |
My understanding is that on a UK car, this defaults to inactive. My FF has autolock enabled because I went in via T4 to activate this feature to the US Spec. I guess someone has manually activated yours at some time in the past too.... @Soggy - Get autolock turned on if you like this feature. It's one less thing to remember after takeoff! 2006 4.2 SC 2019 Renault Zoe Dynamique Nav ![]() |
Ah I see, oh well. I just tried pressing my button and activating the sunroof and it kept resetting to where I stopped it, weird! However with the auto lock it works perfectly. ![]() I agree get the auto lock turned on its a lot easier and apparently different. Bushy 2003 RR Vogue Monté Carlo Blue |
davidmg Member Since: 29 Mar 2013 Location: Nottinghamshire Posts: 63 ![]() ![]() |
My sunroof would open but not close unless you switched the ignition off and on again, then it worked again. I cured it by resetting the sunroof. I have now enabled auto lock and there is no problem with the sunroof operation, therefore try resetting the sunroof to see if that fixes it |
