![]() | Home > Maintenance & Mods (L322) > Won't start after a run |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 ![]() ![]() ![]() |
Not sure sorry .... Someone here will be able to guide you otherwise RAVE will help. |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3983 ![]() ![]() ![]() |
Item 6
reynolds Member Since: 07 May 2010 Location: great yarmouth Posts: 83 ![]() ![]() ![]() |
Hi is that the crankshaft or camshaft sensor |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
Would it be an idea to get the codes read to try and establish the fault before you carry on changing parts? |
@reynolds
I need CAMSHAFT sensor |
I looked that the manual and it seems to sit underneath the inlet pipe from filter to engine on the UK driver side of the car.
Thank you |
Personally I'd say you need to look at the crank sensor not the cam sensor
wslr Member Since: 04 Dec 2011 Location: Wellington, Somerset Posts: 64 ![]() ![]() ![]() |
Most engines will run with a poor cam sensor reading but as mentioned all along, the crank sensor is a critical sensor without which an engine will not run at all.
Took it in today to range rover dealer today problem is it needs 3 injectors to rectify starting problem |
Sorry to hear. It seems to be the month for the TD6 injectors going |
Cmgrob Member Since: 30 Mar 2015 Location: Northampton Posts: 7 ![]() ![]() ![]() |
Just to throw in my 2p's worth, the cam sensor on the td6 is located under the plastic trim on top of the engine, the diagrams above are from the v8 and located in a completely different place 👍 |
