![]() | Home > In Car Electronics (L322) > AV In Front Screen |
Tuts Member Since: 24 May 2012 Location: Bishop’s Stortford, Herts Posts: 201 ![]() ![]() ![]() |
There are a/v leads that add an aux to the tv tuner for the BMW based ranges (search eBay for range rover aux) can't see why they can't make the same leads for the denso based tv tuners (can't see any on eBay though?) might be worth contacting the sellers of the earlier models leads? 2003 Vogue 4.4 V8 Java Black |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35801 ![]() ![]() |
http://www.disco4.com/shop/index.php?act=v...oductId=34 ... - .- -.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16395 ![]() ![]() ![]() |
Stan, the FF already has 3 fakra leads connected... ![]() ![]() |
Speak to these guys? http://www.toysinyourcar.com/acatalog/AV_I...TH_TV.html |
not going to argue with an expert but is not one of those sockets free? [3 sockets on top right]
No no stan... They are all taken... |
so would that be a tv tuner, sat nav and ? ... - .- -.
Reverse camera |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6378 ![]() ![]() ![]() |
I was using my RSE this weekend and found the following:
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1673 ![]() ![]() |
The 3 FAKRA composite connectors are used for:
so its possible to utilise the venture cam input if you dont use it or the rse input if you havnt got it.. ... - .- -.
You can see what's configured through the "753" hack diagnostic screens, oddly I think mine says that RSE isn't fitted, even though it is! Discovery 4 HSE
Rexyboy Member Since: 04 May 2013 Location: Sydney Posts: 2 ![]() ![]() ![]() |
So far the only interface I have found is this one:
i dont think there is anything much cheaper..its the MOST system that makes it expensive.. ... - .- -.
