![]() | Home > In Car Electronics (L322) > Retrofiting a Bluetooth ULF Module |
Budgie Member Since: 09 Jul 2012 Location: Stornoway Posts: 267 ![]() ![]() |
Thanks Andy.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7925 ![]() ![]() ![]() |
Do you have the "eject box" with the pairing button in the front of the car ?
Yep, that makes sense, I don't have the ejector seat in the front |
Remember thay pin 36 needs to be still connected to the ULF when you short pin 32 to it, as it is the earth for the ULF.
I attached a sort piece of wire to a scotchlock around the pin 36 wire. I then partly removed pin 32 and managed to get a stripped piece of wire onto the pin and pushed it back into place. I now have a double choccy block with pin 36 in one side and pin 32 in the other.
We're up & running!!! |
Excellent news.
Worth knowing about it only connecting to one phone, my last BT kit connected paired with both phones when they were in the car.
What's on the screen when you turn the key to position 1?
kiter Member Since: 04 Jan 2013 Location: Inverness Posts: 182 ![]() ![]() |
It says activate phone and if I use the R/T button I get the same message in the dash
Na, I had to do the same.
Good job. |
enjoy........... I need to stop spending money on the car now - so far its had towbar and twin electrics, super charger rear lights, Mk4 dvd navigation, seat covers, roof rails and bars and now bluetooth. Would like to do the Digi TV upgrade but need to save some pennies for that.............
