|  | Home > Technical (L322) > [SOLVED] "Coolant Level Low" - NOT! |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434    |
 I am losing a bit of coolant, @ 1/2 litre every 500 miles (believe slight leak in radiator).
|  9th May 2013 3:35pm |
| Gazellio @ Prestige Cars Member Since: 22 Jan 2010 Location: Chilterns, UK Posts: 11309      | Its the float/level SG sensor in the reservoir I think? | ||
|  9th May 2013 3:39pm |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434    | OK did a test today. Reservoir topped up, floaty thing bobble in correct position.
|  2nd Sep 2013 6:37pm |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35878    | doesnt the coolant have to a certain density? ... - .- -.
|  2nd Sep 2013 7:27pm |
| ebajema Member Since: 24 Mar 2011 Location: New Plymouth Posts: 4782      | Have you tried "overfilling" a bit and then testing again (where the fuzz is not too vigilant) ?  It may be that driving with running engine pulls the level down a bit or that your floaty thing is getting "heavy" by leaking/soaking up coolant (over time). MY 2010 5.0 SC Galway green and sand interior!!
|  2nd Sep 2013 7:30pm |
| 47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048    | Coolant has to be a certain strength or the warning light will come on | ||
|  2nd Sep 2013 7:47pm |
| dave699 Member Since: 03 Apr 2012 Location: Redcar Posts: 457      | As Ebajema suggested in first post, I've also read that the coolant level sensor checks the SG (Specific Gravity) of the coolant. If you've been topping up regularly with water only or a weak mixture, this could be the issue.
|  2nd Sep 2013 9:25pm |
| Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2951      | I have the same problem. My level does drop slightly though but where it's going, I don't know. Never overheats either. | ||
|  2nd Sep 2013 10:25pm |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434    | noddy, do you mean a maintained high rpm generates the coolant message ? .
|  3rd Sep 2013 4:52pm |
| Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2951      | It seems to come on under load, yes. | ||
|  3rd Sep 2013 4:59pm |
| wedgel322 Member Since: 20 Jul 2011 Location: Leeds Bradford Posts: 161      | Mine also does this. I had the fluid changed and had it exact fluid topped up correctly by garage ad it was annoying. . Garage said if it still does it it will be the float sensor that detects volume of water to coolant.  I can get car to sit at  about 76 ish mph and it will be fine all day as in  hundreds if miles but if I keep it for a minute or 2 over that speed I get the bong. I keep my eye on the fluid level and it only wants the tiniest bit every 1000 miles or so, I then top it up 50/50 water/coolent but it wants a cup full if that. 2003 Range Rover HSE 3.0 TD6
|  3rd Sep 2013 6:28pm |
| Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16403      | Change the coolant tank  | ||
|  3rd Sep 2013 7:40pm |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434    | Does that include the sensor then, Craig ? .
|  3rd Sep 2013 11:34pm |
| Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16403      | It does indeed sir  | ||
|  3rd Sep 2013 11:37pm |
| Posting Rules
