Home > Technical (L322) > [SOLVED] "Coolant Level Low" - NOT!
I am losing a bit of coolant, @ 1/2 litre every 500 miles (believe slight leak in radiator).
However, message comes on when coolant level is NOT low, but only when engine is running consistently @ 3k RPM under load, so you guys will know what that means if I am in top gear !
Is coolant level measured by something other than actual coolant level, e.g. pressure/flow to cause this ? .
Post #187464 9th May 2013 3:35pm
ebajema
As far as I know it measures SG of the coolant. In other words, water at the correct level in the tank, still gives a coolant level warning.
But I assume you put proper coolant in anyway.
If that's the case the level sensor may be on its way out. MY 2010 5.0 SC Galway green and sand interior!!
Post #187466 9th May 2013 3:39pm
Its the float/level SG sensor in the reservoir I think?
Post #187467 9th May 2013 3:39pm
OK did a test today. Reservoir topped up, floaty thing bobble in correct position.
Hit the motorway and reached a cruising speed (round figure with an 8 in it) @ 2750 rpm
After about 1 minute, BONG! - "Check Coolant Level"
Can cruise all day at 2500 rpm without fault.
(I'll let you do the calculations Smile ) .
Post #207531 2nd Sep 2013 6:37pm
doesnt the coolant have to a certain density? ... - .- -.
Post #207539 2nd Sep 2013 7:27pm
ebajema
Have you tried "overfilling" a bit and then testing again (where the fuzz is not too vigilant) ? It may be that driving with running engine pulls the level down a bit or that your floaty thing is getting "heavy" by leaking/soaking up coolant (over time). MY 2010 5.0 SC Galway green and sand interior!!
Post #207540 2nd Sep 2013 7:30pm
Coolant has to be a certain strength or the warning light will come on
Post #207544 2nd Sep 2013 7:47pm
dave699
England 2007 Range Rover Vogue SE TDV8 Stornoway Grey
As Ebajema suggested in first post, I've also read that the coolant level sensor checks the SG (Specific Gravity) of the coolant. If you've been topping up regularly with water only or a weak mixture, this could be the issue.
http://en.m.wikipedia.org/wiki/Specific_gravity apologies for the link being a mobile site version
Had it, loved it!
2007 Vogue SE TDV8
Stornoway Grey / Ivory
Climatic Seats, RSE, AFS, Deployable steps, iPod kit.
Post #207593 2nd Sep 2013 9:25pm
Andy
I have the same problem. My level does drop slightly though but where it's going, I don't know. Never overheats either.
Post #207620 2nd Sep 2013 10:25pm
noddy, do you mean a maintained high rpm generates the coolant message ? .
Post #207735 3rd Sep 2013 4:52pm
Andy
It seems to come on under load, yes.
Post #207738 3rd Sep 2013 4:59pm
wedgel322
United Kingdom 2013 Range Rover Autobiography SDV8 Santorini Black
Mine also does this. I had the fluid changed and had it exact fluid topped up correctly by garage ad it was annoying. . Garage said if it still does it it will be the float sensor that detects volume of water to coolant. I can get car to sit at about 76 ish mph and it will be fine all day as in hundreds if miles but if I keep it for a minute or 2 over that speed I get the bong. I keep my eye on the fluid level and it only wants the tiniest bit every 1000 miles or so, I then top it up 50/50 water/coolent but it wants a cup full if that. 2003 Range Rover HSE 3.0 TD6
Java Black, Cream Leather Heated seats all round, Sat Nav, Rear TV's.
2013 Range Rover Autobiography 4.4 SDV8
Black, black and piano black. Rear entertainment system. 22 inch turbines
Post #207756 3rd Sep 2013 6:28pm
Change the coolant tank Thumbs Up
Normally solves this issue Thumbs Up
Post #207769 3rd Sep 2013 7:40pm
Does that include the sensor then, Craig ? .
Post #207819 3rd Sep 2013 11:34pm
It does indeed sir Thumbs Up
Post #207820 3rd Sep 2013 11:37pm
