![]() | Home > In Car Electronics (L322) > Another faulty reverse camera. |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3949 ![]() ![]() ![]() |
Cheap NTSC camera from eBay, changed connectors on car to match camera, stuck in place with double sided tape, bent mount to get decent coverage behind - 12 quid all in and much better than original camera which got damaged when rear spoiler detached on motorway. |
No doubt that its better - lots better than what I had previously, but I don't know how it compares to the 2010 onwards camera set up which peeps seem to be going for. Geoff |
Tayas Member Since: 29 Apr 2013 Location: United Kingdom Posts: 74 ![]() ![]() |
Which did you buy? Got a link? 2006 FFRR 4.2 Supercharged Vogue SE
eBay Item No. 261050835380 on eBay Geoff |
Thanks. Ordered one myself. 2006 FFRR 4.2 Supercharged Vogue SE
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 884 ![]() ![]() ![]() |
As my reverse camera stopped working, I tried JustinP’s solution, which is to reflow just the solder joints around the camera sensor. This cured the problem and now the camera has been working for 2 days.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35832 ![]() ![]() |
that 420 resolution should be better than the standard OE cam.. ... - .- -.
It should… I’m just worried about the NTSC/PAL compatibility, but at this price it’s not really a problem… One thing to have in mind, during my tests I accidentally plugged the 12v camera connector in the 3rd stop lamp’s one (they are both black and similar in shape) which led to fuse no. 12 from the back blowing (5A) and to one more hour of testing before finding the fault… |
the pal/ntsc issue shouldn't be a problem as that ebay cam works on both [allegedly] ... - .- -.
10 days later the camera is still working great with the resoldered points around the image sensor... |
Well, the ebay camera is not here yet, but the soldered one is still going strong! |
VMPP Member Since: 12 Jul 2009 Location: Lisboa Posts: 412 ![]() ![]() ![]() |
Well...
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2291 ![]() ![]() ![]() |
Thanks for this write up, just repeated what you did and the camera works again. |
Ollie_247 Member Since: 26 Nov 2015 Location: Buckinghamshire Posts: 35 ![]() ![]() ![]() |
Does anyone know the Part no for the 2010 upgrade. my 2007 one has just given up and I have the black screen of death / faint picture.
