Home > In Car Electronics (L322) > Another faulty reverse camera.
Page 3 of 4 <1234>
supershuttle
Cheap NTSC camera from eBay, changed connectors on car to match camera, stuck in place with double sided tape, bent mount to get decent coverage behind - 12 quid all in and much better than original camera which got damaged when rear spoiler detached on motorway. Whistle Geoff
Post #189175 18th May 2013 9:55pm
ebajema
I love how you say that "when it detached on the motorway" Rolling with laughter Rolling with laughter Rolling with laughter
I wonder if you can get a much better camera than original, still great that you got a cheap one and it works well Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #189177 18th May 2013 10:00pm
supershuttle
No doubt that its better - lots better than what I had previously, but I don't know how it compares to the 2010 onwards camera set up which peeps seem to be going for. Geoff
Post #189183 18th May 2013 10:14pm
Tayas
Which did you buy? Got a link? 2006 FFRR 4.2 Supercharged Vogue SE
2007 Honda S2000
2008 Aprilia Tuono Factory
Post #189189 18th May 2013 10:35pm
supershuttle
eBay Item No. 261050835380 on eBay Geoff
Post #189191 18th May 2013 10:42pm
Tayas
Thanks. Ordered one myself. 2006 FFRR 4.2 Supercharged Vogue SE
2007 Honda S2000
Post #189201 19th May 2013 12:32am
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
resoldering camera sensor did the trick
As my reverse camera stopped working, I tried JustinP’s solution, which is to reflow just the solder joints around the camera sensor. This cured the problem and now the camera has been working for 2 days.
However, as I checked the connections using a regular home surveillance camera and got much better results than with the standard one, I ordered this camera:
http://www.ebay.co.uk/itm/321378896726?_tr...EBIDX%3AIT
I believe it will be better and I will post the result when it arrives.
Post #286792 16th Oct 2014 10:22am
that 420 resolution should be better than the standard OE cam.. ... - .- -.
Post #286795 16th Oct 2014 10:35am
adara
It should… I’m just worried about the NTSC/PAL compatibility, but at this price it’s not really a problem… One thing to have in mind, during my tests I accidentally plugged the 12v camera connector in the 3rd stop lamp’s one (they are both black and similar in shape) which led to fuse no. 12 from the back blowing (5A) and to one more hour of testing before finding the fault…
Post #286798 16th Oct 2014 10:42am
the pal/ntsc issue shouldn't be a problem as that ebay cam works on both [allegedly] ... - .- -.
Post #286799 16th Oct 2014 10:44am
adara
10 days later the camera is still working great with the resoldered points around the image sensor...
Post #289197 27th Oct 2014 3:51pm
adara
Well, the ebay camera is not here yet, but the soldered one is still going strong!
Post #294007 18th Nov 2014 8:05pm
VMPP
Portugal 2007 Range Rover Vogue TDV8 Buckingham Blue
Well...
Seems that my camera is also packing up. Sometimes I get the black screen and sometimes I get the picture black and white, and other times it flickers.
I tried to access the camera connections, took it apart, well... couldn't take away the single screw holding it in place so I kinda forced it out.
While I was fiddling with the camera, the picture came on ok. So I mounted everything back again But the next day it was out again.
Now, i'm not going to go to the option of the 500 camera Shocked
So, anyone tried those ebay cameras?
While taking it apart I noticed that the plug has 4 wires going into the circuit board, but I have no guide-lines. Just a simple image.
Any help, fully appreciated...
Post #302873 5th Jan 2015 4:23pm
Robert
France 2007 Range Rover Vogue 4.4 V8 Zambezi Silver
Thanks for this write up, just repeated what you did and the camera works again. Bow down Bow down Bow down Thumbs Up Thumbs Up and that for a non tech, I like myself Embarassed
Post #325964 4th May 2015 4:23pm
Ollie_247
United Kingdom 2007 Range Rover Vogue SE TDV8 Orkney Grey
Does anyone know the Part no for the 2010 upgrade. my 2007 one has just given up and I have the black screen of death / faint picture.
I found the costs If not I will email Dan I guess.
2010 non-vision assist camera for £90 the loom for £30 and the holder for £5. The MOT Track days Test Dummy
2007 Vogue SE TDV8
Post #393241 27th Jun 2016 11:24am
Page 3 of 4 <1234>
