Home > In Car Electronics (L322) > Entertainment System Wont Switch On
marcoos_1
Scotland 2006 Range Rover Supercharged 4.2 SC V8 Java Black
For some reason my entertainment system is frozen with the 'LandRover' screen. It won't turn on and nothing is working when I try the satnav, offroad display etc etc.
There was no warning...it seems to have just given up on me.
Can anyone help? I've heard water in the rear left might be blamed, but how do I fix this problem if water is getting in, and which module do I now need to replace?
Thanks in advance for any help you can offer.
Post #190202 23rd May 2013 8:27pm
disconnect the battery for about 30 minutes....details hwo to are in the wiki.. ... - .- -.
Post #190204 23rd May 2013 8:28pm
I have had this with water in the Bluetooth module... There are loads of posts about this. You can bypass the Bluetooth module and it should fire up the rest of the kit.... If indeed that was the problem ! Previously..
Post #190205 23rd May 2013 8:30pm
marcoos_1
Thanks Guys,
I'll give both these a try today.
Mark.
Post #190258 24th May 2013 7:29am
SATVC
United Kingdom 2004 Range Rover Vogue Td6 Java Black
Mine did this!! Turned out to be the satnav unit failing!
Post #190590 25th May 2013 7:31pm
alan
2002 Range Rover Vogue Td6 Alveston Red
Mine did this as well when I use the spare key all I do is pull the 2 fuses (not sure on the numbers off hand) and it works again.
Post #190595 25th May 2013 7:55pm
